1992 F-150 Extended cab seat cable
on
It is an EASY repair- First, unzip the bottom of the cover, and remove it. Then, remove the bits of the old cable. Then make yourself a new one using .041" stainless safety wire. Slide the safety wire right through the same conduit the original cable used.You can adjust the tension once it is in place, as I recall... Once in , put the cover back on. Takes about half an hour or less... And a lot easier and less costly than trying to look up an original! All you are doing is direct connecting the handle to the little catch... I had to do it on my old seat a while back.(Later I transplanted the twin buckets with the floor console)
Scott
Scott
there is no ?zipper? looks to be more like a mulling strip, narrow strip that joins the front and back bottom edges together, worried that if it breaks coming off then i will need that also, even if i can just find something close to the factory ends that are crimp-able to cable , the sharp edges of the lever are going to cut a cable
on
Scott
Later ones had the plastic strip instead of a zipper - or maybe it was the seats with 1-piece backrests, not sure. The '95 XL I had apart recently had the plastic strips sewn to the cover, and the snap-over U-channel holding them together - this one slipped apart just fine, I suppose it could break, but this one didn't.....
And yeah, a replacement wire is what I used - I slipped a little piece of copper tubing over it, through the holes, and tried to crimp it down, but ended up with twists to hold it. It appears to work fine - I also tried to make a bushing out of tubing to armor it in the hole, but it didn't really work - but like was said, not much tension on it, I think it'll hold up for quite a while as-is.
RaventreeJohn
01-04-2024 08:57 AM
larcou
08-27-2016 08:03 AM
JBronco
1978 - 1996 Big Bronco
02-13-2005 07:10 PM
