I owned a 2001 Excursion with 4WD. I sold it because it wandered all over the highway. You could not take your eyes off the road or you were in the ditch.
I am looking at a new 2016 SD PSD 4WD at a really good price. I do not need 4WD, but the truck I am looking at has it (I am talking a $56k MSRP truck for $40k brand new).
I am told that the front suspension in a 2016 is heavily revised from 2001 and the trucks do not wander like they used to.
I have an '03 F-350 and it does not wander, I have driven several others from a '99 to a '16 and the only one's that wander have something worn out/ out of adjustment in the front end or under inflated tires. I do know of 1 '06 that was so far out of alignment from the factory that wandered badly untill it was realigned.
I ask the question because I read a similar post a while back. Someone complained of wander in an earlier SD and someone else replied that the front ends were different on newer models and the wander had been fixed.
I was constantly sawing on the steering wheel on my Excursion. The truck was just very tiring to drive for 8-10 hours at a time.
My '99 SD, '00 SD, '06 Dodge and my 2010 SD (all 2WD), I could take my hands off the wheel and go 1/4 mile or more before I would drift over the line.
I was aware of the soft rear end in the excursion, but the op didn't mention this was while towing.
The biggest issue that can cause front end problems on the newer trucks is the ball joint end on the trac bar. When it wears, it can cause the front axle to have side to side movement. It's easy to replace, and easy to fix with an aftermarket eliminator. But most will not have issues until high mileage.
The wander in '99 to '04 trucks can be fixed by replacing worn out components.
Yes the Excursion suspension is too soft for towing what it's rated for. That's why most people upgrade the suspension. I have V/B code springs, a Hellwig, and Bilstein shocks. I use a WD hitch with a friction anti-sway bar. I don't get any wander, unloaded or not. The steering might be a little loose but a Redhead gearbox will fix that if it starts to bother me enough.
I bought the truck brand new. So nothing was worn out.
So how do you explain the millions of trucks of this era that don't exhibit any wandering at all?
I'm not doubting your statement or your experience, but my truck doesn't wander. Many others have trucks that don't wander. There must have been something about that truck that caused that behavior because it's not normal.
The front axle and suspension has been dramatically improved in newer trucks, there is no doubt about that.
Curious jschira did your Excursion have Goodyear Wrangler tires on by chance? I know on my 2000 Expedition it had Wranglers on it and they were awful about "wondering" all over the place... If felt like the sidewalls were just way to soft to support the weight of my Expedition..........
