2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Home screen display
Old 02-09-2017, 05:13 PM
activepat's Avatar
activepat
activepat is offline
Home screen display
I searched but see nothing. My luck. How do you set the main, center instrument display when you start the truck. Mine reverts to "tow" everytime I start the truck. It's a 2017 Lariat 4x4.
Am I an idiot?
Old 02-09-2017, 05:16 PM
srkr's Avatar
srkr
srkr is offline
You must select no active trailer while in park or truck not moving.
Old 02-09-2017, 05:17 PM
Rutcutter's Avatar
Rutcutter
Rutcutter is offline
Yea try what srkr said...
Old 02-09-2017, 05:19 PM
hwheeler's Avatar
hwheeler
hwheeler is offline
You have to go to the trailer menu and chose no trailer. It thinks you still have a trailer hooked up. And no, you're not stupid. Many others including myself have had to discover this. Ford needs to redo its software so that when you disconnect a trailer the truck realizes itt just like it notices when you hook one up.
Old 02-09-2017, 06:15 PM
rocket_scientist's Avatar
rocket_scientist
rocket_scientist is offline
I believe the reason they require you to say "no active trailer" is so that if a wire in the harness/plug breaks it won't think you've disconnected it. They may consider it a safety feature since the truck behaves a little differently when a trailer is connected. (whatever trailer sway control is. And it calculates DTE differently.)
Old 02-09-2017, 06:36 PM
DIDit4DAD's Avatar
DIDit4DAD
DIDit4DAD is offline
I've had to select "no trailer" like 5-6 times and i still don't remember where I found it last time...
Old 02-09-2017, 07:43 PM
activepat's Avatar
activepat
Perfect answer, guys. It makes sense now. I trailered and messed around in that mode and the problem started right after.
Thank you!
Old 02-10-2017, 06:11 AM
activepat's Avatar
activepat
Verified this morning. That was the ticket. Thanks all.
Old 02-10-2017, 07:49 AM
klassic's Avatar
klassic
klassic is offline
The disappointing thing about this "feature" is everythime you forget, you are clicking off recorded miles on the trailer you had selected. If you want to keep accurate track, which is what that trailer odometer is for, it is useless.
I have 3 trailers setup in the menu. I forget everytime to go to no active trailer.
I always notice while driving...can't change it while driving!
After I stop, I've forgotten. Notice next time I'm driving...can't change it while driving!
My miles are all wrong now.
Again, nice feature Ford.....again (like some others), poorly thought out.
Flathead2755
2017+ Super Duty
07-06-2023 09:07 AM
Ewags
2017+ Super Duty
07-22-2018 10:59 PM
senix
2017+ Super Duty
09-03-2017 12:32 PM
DavidK2017
2015 - 2020 F150
05-11-2017 02:14 PM
baronmic1
2015 - 2020 F150
01-09-2017 12:31 PM
Quick Reply: Home screen display
