Am I being hosed?
Old Feb 9, 2017 | 01:56 PM
6.whoa's Avatar
6.whoa
Am I being hosed?
The other day I replaced fuel filters and changed the oil,put in two new batteries and a alternator. The next day the truck wouldn't start at the store,was turning over just fine. Towed it to a local shop here in colorado,they are saying it needs a new motor. I didn't have any knocking or any other symptoms of a blown motor to my knowledge.. if I do need to replace the motor does anyone have a idea of cost accosciated with this kind of job? I've put so much money in this truck and it continue..
Old Feb 9, 2017 | 02:00 PM
Per4mance's Avatar
Per4mance
Hose job for sure. Find another shop that specializes in 6.0. You drive it there right,no strange noises. I'll bet it's got a good HPO leak.
Old Feb 9, 2017 | 02:11 PM
Bumblebee04's Avatar
Bumblebee04
I wonder how many new engine replacements ford stealerships have gotten away with due to uneducated techs LoL
DEFINITELY get a 2nd opinion
BLADE35's Avatar
BLADE35
Originally Posted by Per4mance
Hose job for sure. Find another shop that specializes in 6.0. You drive it there right,no strange noises. I'll bet it's got a good leak.
X2 TOTALY AGREE WITH ^^^^
Old Feb 9, 2017 | 02:26 PM
Euroman's Avatar
Euroman
X3 how do they they justify that statement?
Old Feb 9, 2017 | 02:35 PM
FiznUKa's Avatar
FiznUKa
I would revisit what repairs you just did even if that means removing the filters and reinstalling. Check the connections. on the alternator also.
Old Feb 9, 2017 | 03:10 PM
navistarnut's Avatar
navistarnut
He stated "local shop" so don't jump the shark that this is a dealership.
Plenty of those I realize, but it's more often than not the "local shop" that has no clue about a 6.0
Old Feb 9, 2017 | 03:11 PM
navistarnut
What are you using to monitor? Motorcraft oil filter and cap?
Old Feb 9, 2017 | 03:15 PM
Tideman's Avatar
Tideman
To answer your question from the information you gave. YES YOU ARE GETTING HOSED!!!
Old Feb 9, 2017 | 03:29 PM
WatsonR's Avatar
WatsonR
Thank you Mike.
Let's see some numbers before condemning a motor or a shop. The wrong cap and filter can cause this issue.
Old Feb 9, 2017 | 04:06 PM
Bumblebee04
My mistake. I always have a tendency to jump the gun on blaming "professionals". Have rarely ran across people in many different professions that actually knew their job. Can't even count how many times I have paid a "pro" to end up just having to learning how to do it myself to fix the problem correctly.
Apologies to the OP. The most important tool EVERY 6.0 owner should have before they drop a dime on any repairs is a scanner of some sort. The cheapest route is a Bluetooth obd2 adapter & torque pro(android) or forscan(ios) app. This will help you diagnose your truck and get you on the right path to doing repairs that solve the actual problem.
Old Feb 9, 2017 | 06:42 PM
Maxium4x4's Avatar
Maxium4x4
You may have botched the lower O-Ring on the HFCM when you changed fuel filters, see if you are getting fuel first and do find another shop. Things do not add up.
minitrail
6.4L Power Stroke Diesel
Oct 28, 2016 11:41 AM
2006powerstroke90
Apr 9, 2012 06:59 PM
kaboom10
Michigan Chapter
Dec 30, 2009 08:09 AM
4inchlovin
18
Apr 9, 2008 01:14 PM
MineralStang
Colorado Chapter
13
Jan 7, 2005 01:09 AM
