78 F150 Engine upgrade
Old Feb 8, 2017 | 09:49 AM
BLK79's Avatar
BLK79
All good advice regarding cam advance, makes a BIG difference on 351M/400 engines, especially when coupled with a max 600 cfm 4 bbl carb/dual plane intake (Performer, etc). Highly recommend upgrading to 400. 1/2" more stroke =noticeable torque increase. All you need is source 400 crank and pistons. Block, rods, heads all the same. The harmonic balancers were different in appearance from the factory, 400 thicker than 351M, but I always heard/read the replacement part from Ford was the same. Not 100% sure on that.
Old Feb 8, 2017 | 10:25 AM
79F150400M's Avatar
79F150400M
The original 351M that I started with ran great, had awesome power and great reliability until the fuel pump went which leaked gas into the oil and chewed up the conn rod bearings. And that happened at 185K miles. Im sure it would have easily made it to 200K if it wasn't for the fuel pump. ( I didn't catch it in time). Also on that engine I was running a Comp Cams 268, Crane screw in stud kit and a new timing chain installed straight up. Edelbrock intake and a Carter 625 breathing through headers and glass pack mufflers. As for the LS question...I wouldn't do it. I'm sure there would be lots of fab work involved. As others have said....351M-400 will drop right in. A 460 or 429 will too but you need different motor mounts. Lots of threads on that swap.
Old Feb 8, 2017 | 10:54 AM
BLK79's Avatar
BLK79
I have 2 79 Broncos I've done 460 swaps in. Both were early 90's EFI engines that I converted to carb, other than that all stock. Still have another 79 and a 78 with 400's, which have both had the cam advance and 4bbl intakes/carbs. Can't really tell any noticeable performance difference between the 460's vs 400's. I do realize the 460's have more potential, and the EFI engines were not hot performers by any means, but neither were the 400's factory either. The 460's look nicer with the serpentine belt setup, but driving one vs the other I wouldn't know the difference. I CAN tell a difference between an otherwise equal 351M vs 400. Due to the stroke difference no doubt. 400's have a 4" stroke which is even longer than the 460's at 3.85.
Old Feb 8, 2017 | 11:26 AM
JakeHan's Avatar
JakeHan
Not familiar with Atomic, but FITech systems seem to be relatively popular and cost-effective, depending on what you're going "driveability" wise. Nothing wrong with a well set-up 4BBL, but for a DD, I'm really really considering an FITech setup.
I have a box-stock 400 in one pickup, and a 351M in another with a dual-plane Edelbrock manifold, a Holley 4BBL, RV Cam of some sort (bought it that way, not sure what it is), straight-up timing, and headers, otherwise virtually the same pickups. Both are F250 4x4's, 4 speeds, 3.55's, stock tires - other than the 351M has a heavy flatbed and hoist compared to a regular box - and the 351M runs like a scalded dog compared to the 400. So even a mildly built 351M is a heck of an improvement over a stock anything from the late '70s........
What do you guys think as far as compression ratio / stroke? For a DD that will get pump gas and nothing fancy, are you better off with a 351M stroke? I only ask because I remember a couple 383 Chevys around here that were runners, but were a little too hot to run good on normal gas, they had to run premium AT LEAST - I'd like to stay away from that drama, and run anything in it.....
Old Feb 8, 2017 | 01:31 PM
Hod's Avatar
Hod
I hope this is the right place.
I'm trying to fined out if I can put a newer efi of a motor and put it on my older 78f150 4wd 5.8l? If I can?witch ones will work?
Old Feb 8, 2017 | 05:46 PM
Blue and White's Avatar
Blue and White
Originally Posted by DB429SCJ
Rebuilding the 351 will be much easier. The 347 is based on the 302 block. It will not bolt up to your transmission.
Besides the bolt up issues, the 347 is a smaller displacement shorter stroke engine. It makes power at high RPM. A truck needs torque and lower RPM power... a moderately built 351m or better yet a 400 will work much better I think.
Old Feb 8, 2017 | 06:46 PM
JakeHan's Avatar
JakeHan
Ford started fuel injected 351W's in the late 80's(?). They weren't a really great design, according to most, and are still 25 year old technology. And, since NOTHING is really common between a Windsor, 335, or 385 engine family, there isn't much that will bolt on to an M - it's easier to put a Chevy TBI on it than another Ford part..... And they weren't great.
Old Feb 8, 2017 | 11:58 PM
HIO Silver's Avatar
HIO Silver
Well here's my take.... build a 400, port match the heads n intake, Terminator/Sniper/FI Tech/E-Street EFI, straight up timing, and headers with dual exhaust.
Doable, simple, and relatively cost effective.
Intake? Weiand Action Plus
Old Feb 9, 2017 | 05:16 AM
SlikWillie's Avatar
SlikWillie
How long have you had this truck? Did you change the oil when you bought it and if so, what oil did you use? The type of oil that you use at 3000 miles after a rebuild is critical to moving parts. I may be beating a dead horse here, but the correct oil to use has high levels of ZDDP (zinc) up to at least 5000 miles after build. I thought I was good to use normal conventional oil at 3000 miles after my rebuild and I wiped a cam lobe and lifter. Sounds just like a rod knock. My lower end was fine. All I had to do is replace the cam and all the lifters and I was good. I still use high zinc oil just for piece of mind.
Two months ago, I rode in a buddy's '79 Bronco with a bone stock '85 460. What a difference! He ditched his tired old 400 and he couldn't be happier. Claims he gets an average of 12.5 mpg, double the power, and it was a very easy install. He's also running on 33" MTs, C6, and 3.55 gears. I've gotten over $1500 in my rebuild and he has under $800 in his engine swap. It ticks me off when I really think about it. I could have install a 460 plus gone EFI for less than I have in my 351M.
lakequ
59
Nov 25, 2017 07:22 AM
DEWITTAUTOTECH
Aug 15, 2013 09:09 PM
Justin's Green Truck
Nov 12, 2009 09:53 PM
yamahafella03
Feb 7, 2009 11:25 AM
superscythe
May 11, 2003 09:26 PM
