transmission
Old Feb 6, 2017 | 09:47 AM
Vinford's Avatar
Vinford
transmission
I was looking at a 1978 F-100 shortbox 2wdr
Its got a 302.
The transmission is a 3 spd with a overdrive on the floor.
The guy says its stock?
Anyone know?
Old Feb 6, 2017 | 09:54 AM
good to doo's Avatar
good to doo
Yes they are. Fully synchronized also.
Old Feb 6, 2017 | 10:00 AM
Vinford's Avatar
Vinford
Are they rare?
Old Feb 6, 2017 | 12:03 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Vinford
I was looking at a 1978 F-100 shortbox 2WD .. Its got a 302.
The transmission is a 3 spd with a overdrive on the floor. The guy says its stock?
RUG SR-OD Single Rail 4 Speed Overdrive:
1978/83 F100/150 2WD 300/302 / 1980/83 F150 4WD & Bronco 300/302.
Originally designed for mid-sized passenger cars, installed in F100/150 and later Bronco after the first Arab (OPEC) Oil Embargo (1973/74).
The second Arab Oil Embargo occurred in 1979.
Old Feb 6, 2017 | 03:41 PM
Vinford's Avatar
Vinford
You call it a 4 speed overdrive?
Is that a different one than I'm talking about or just what its called?
The one I'm talking about has 1, 2, 3, and OD. reverse is where 1st is on most 4spds
Old Feb 6, 2017 | 03:50 PM
gittinwidit's Avatar
gittinwidit
I have one stock in a 79 E150 van. It's 3 speed with 4'th overdrive. Although it works, the shifter had excess slop. But it worked flawlessly.
Old Feb 6, 2017 | 05:33 PM
NumberDummy
You call it a 4 speed overdrive? Is that a different one than I'm talking about or just what its called?
Same transmission.
RUG SR-OD = This is the only 4 speed M/T with overdrive FoMoCo offered for 1978/83 F100/150 & 1980/83 Bronco.
1978/83 E100/250's were also available with it, though the SR-OD's Econoline shift lever is completely different.
hooterville
Jan 27, 2019 11:20 AM
NM33013
Mar 16, 2018 10:31 AM
tdawglp
WTB - Parts & other
Nov 4, 2015 05:42 AM
anthony myrick
Feb 27, 2015 04:00 PM
moneypit79
Jun 25, 2013 09:08 PM
