About to put my truck back together. I need a few parts, namely a torque converter, flexplate and a harmonic balacer. Truck is a 78' with a 302 and a C4. Any input I to what i need to get is appreciated.
I think summit and jeggs would be the easiest place to get all the parts you need and have choices for after market parts. I have seen thicker flex plates. I am going too order one for my c6 when I pull my truck down to do a few upgrades. The torque converter should be close to the same operating rpm of your cam.
Is the 302 original to the truck? If so, then you would want a 28 ounce imbalance flywheel/flexplate and harmonic balancer. The 302 changed to a 50 ounce imbalance spec in 1981 I believe.
The best indicator of what you have/need is the part number on the crank.
Yes its original to the truck. Appreciate the info.
