How do you remove interior door panels?
Old Mar 26, 2007 | 03:16 PM
bnuvp's Avatar
bnuvp
The right rear passenger door lock solenoid is acting up, won't unlock completely. So, how do you remove the plastic interior panels on a 2000 Ex? Pictures would be nice but not required.
Thanks,
Bob
Old Mar 26, 2007 | 04:12 PM
SPL Tech's Avatar
SPL Tech
They are very easy to remove. You will need a 7 MM nut driver. There is a couple of 7 mm nuts you need to take out. There is one in the light housing in the bottom of the door panel and there is one in the area where the window and door switches go. Use a panel popper to pop off the switch housing. That is the housing that holds all the window and door lock switches. After you got the nuts out you will need to remove the panel that is on the top of the door panel in the left most corner. It’s the cover that goes over the part of the door where the side mirror is. In all the Excursions I have seen this piece is a different color then the rest of the panel. In my vehicle it’s black and my door panel is tan. This piece only has clips on it so all you need to do it pry it off with a panel popper. After this the entire door panel will slide UP. Grab on the bottom of the door panel and the handle and slide the whole panel up and out. After you get it off don’t forget to unhook all the wires.
Old Mar 26, 2007 | 04:25 PM
X-OvrDistortion's Avatar
X-OvrDistortion
SPL, he is asking for the rear door....
Take off all the nuts and slide up. They are the most simple panels I have ever taken off a vehicle.
Old Mar 26, 2007 | 06:26 PM
SPL Tech's Avatar
SPL Tech
Oh. oops. I dident see that. lol
Old Mar 28, 2007 | 04:40 PM
bnuvp's Avatar
bnuvp
Thanks guys. I sprayed the lock mechanism and the manual pull thingy with WD-40 while I was waiting for a reply. Well, it's working again without me disassemblying the door panel. I do appreciate the answer though. Thanks again. (this truck does love WD40)
Bob
Old May 22, 2007 | 05:57 AM
MLCRI$I$ II's Avatar
MLCRI$I$ II
Found the DOOR PANEL REMOVAL post.
Is there a post about removing the FRONT DOOR panels? I searched and found this post. THANKS. I'll keep looking.
Found it in CUINAK's gallery! Sorry, guess I posted too soon.
Old May 22, 2007 | 10:00 AM
Neal 97 250's Avatar
Neal 97 250
Superduty door panel removal
First, remove the sail panel on the door. It pulls straight off.
Next, remove the door control panel housing. Pull the front up, then pivot the back out of its clip. Disconnect the wiring. Remove the 7mm screw (arrow).
Remove the courtesy light lens with a flat-bladed screwdriver or similar tool. Remove the 7mm screw (arrow).
Remove the door panel by lifting it straight up. You'll need to unplug the courtesy light connector (if so equipped).
The rear door is the same.
WARNING: The following is long winded, but if you want your PDL's to work again WITHOUT spending any $$ read on.
I finally got tired of my non-working PDL's and decided to tear into my truck and find/fix the problem. There has been many discussions about possible issues and I have concluded that the majority of us are seeing actuator motor problems and not relays, switches etc. Ill start by saying the problem I have had is that when I hit the switch, the locks attempt to move and after repeated attempts, the signal appears to get weaker and weaker until nothing....I assumed relay or switch.....NOT THE CASE!
First I started by testing the signal at the harness plug to the actuator. Perfect. No issues here. Next I completely removed the actuator/lock mechanism and bench tested them with 12V..Here lies the problem. The actuator acted the same as when in the truck. First I did a thorough cleaning of all of the mechanism so it works freely and still had the same results. Here's where it get's tricky. These things are built so that they are NOT serviceable. I had already decided that they were going to need to be replaced, so I decided to break them open for closer inspection. It comes apart relatively easily, but appears that It cannot be put back together once apart. I drilled out two small rivets and then pried the case apart. As you pry the case apart you'll notice these small little plastic rods protrude up through the case cover. These rods are then "mushroomed" with heat through the upper case and then sealed with some kind of silicone. When you pry apart the case the "mushroom" head breaks off and the rod remains. You can dig out the silicone and mushroom head with a pick. It comes out very easy. Inside you will find a very small motor and some gear mechanism. I believed the problem at first to be worn brushes or dirty commutator contacts in the motor itself. You'll have to bend two little metal tabs out and pull off the brush housing on the back of the motor. I cleanded the gunk off the brushes and took 1500 grit to the commutator contacts and reassembled the motor. The motor worked, but if you applied even a slight amount of resistance on the armature, it would stop the motor. It should have been WAY stronger than this. I was stumped until I looked a little closer at the inside of the plastic brush housing. Inside you'll find a small, thin rectangular (thermal resistor relay, dodad, thingamabob??) pardon my ingnorance, but I'm not sure what to call it. All I know is that this little part is what keeps you from burning up the motor, should you continue to press the switch once the lock has been actuated. It appears that this thing wears out over time and will not allow enough signal to get through to the motor to make it work. THE FIX . I am cheap. Since I had done so much work up to this point, I decided that I would go a little further and try to make it work without spending the $$. I have better things to spend my money on than actuators. I took a small piece of aluminum foil and wrapped the "thing" voila! Perfectly working motor! I sat there and operated the thing for 10 minutes including one or two times stopping the armature and holding down the switch to see what would happen. The motor builds heat, but not much. Not enough to worry about. Now that I had a good working motor I decided I would try and reassemble the unit. The problem is you cannot glue the unit together as there is a rubber gasket around the perimiter of the case and if you tried to glue the rods into the case, you would not have enough pressure on the two halves of the case to keep the gears in place (these things actually apply a great deal of torque on the case) What I decided to do is completely break off the plastic rods flush with the bottom side of the case and then drill out the bottom case and screw it together. This worked perfectly. You'll need screws that are the same diameter as the holes in the top of the case to keep it from "wandering". Also the screws should not protrude through the back of the unit as some of the mechanism has some pretty close tolerances and a screw sticking through the back would not allow some of the mechanism to work (this can be remedied with a decent set of wire dikes or a hacksaw). I know all of this is hard to picture, but if you do decide to try this fix, you'll see what I am describing here. The locks are back in and working flawlessly.
BigRobK
Jun 25, 2013 10:34 PM
fairlaniac
Jul 3, 2008 02:04 PM
unioncreek
Oct 17, 2003 01:17 AM
bobward737
Mar 31, 2003 10:12 AM
