t-fitting on oil canister
Does anyone know if the T-fittings that go on the side of the oil filter canister is still available? It has a .060 hole to resist oil flow. I went to take it of the canister an broke the dang thing off. I have a similar set up on another flat head out in the back shed that has a strait fitting and the oil sending unit is lower on the block. I would like to save that setup for that engine. Dale
The straight fitting is still available, nowhere I know of for the Tee.
NAPA: https://www.napaonline.com/en/p/WH_1512
Thank's Ross for looking up the part number for me. I'll have to think on which way to go on on that one. It will be a bit before we get to that step. We painted the engine last night.We used Bill Hirsch Lin Merc Lt green from a spray can. Two can's were enough to do the job. It looked good last night. We'll have to see what it looks like this morning in a better light.
