Flathead Oil Primer
Old Apr 20, 2007 | 09:33 PM
cts1954's Avatar
cts1954
Flathead Oil Primer
Making progress, tried my oil primer pump tonight, works perfect. Made it out of an oil furnace gear pump and motor with a plastic peanut butter pail mounted on top for a reservoir. Pumped it in at 60 psi. Next step fire it up, after I added a few missing parts.
wgc
Old Apr 20, 2007 | 09:45 PM
ALBUQ F-1's Avatar
ALBUQ F-1
That's a good lick! They're tough to prime. Where did you tap into the system, at the rear of the block?
Old Apr 21, 2007 | 07:51 AM
cts1954's Avatar
cts1954
My block has three holes in the back of the block, one went to the oil filter, one had the oil pressure sending unit, and the side hole was plugged. I plugged the first two and pumped the oil in the side port. I think I read to pup it in where the oil pressure sending unit goes but this is the same place. I am going to run it through severl times then put some new oil in it.
wgc
