Chasing ignition problems
Old Jul 25, 2018 | 12:55 PM
  #46
R&T Babich's Avatar
R&T Babich
Originally Posted by Skauber
According to Rockauto, the 2000-2002 used the Melling M176, so that seems correct. My truck is a 05, .... Anyway, the Melling pumps will most likely be the ones with improved back plate. .... I'm sure it's possible to call Melling directly and ask what they recommend for your application.
Contacted Melling about the M176 pump and they said " Our pump features a cast iron cover plate, and cast aluminum body, the OE cover plate is stamped steel. "
Old Jul 25, 2018 | 01:27 PM
  #47
Skauber's Avatar
Skauber
Great, that's the one I'd get then in your case. If I end up doing a timing job, I'll be replacing the pump with a Melling high volume pump to ensure proper oil flow and pressure in the engine, as recommended by those who do these timing jobs pretty much on a daily basis.
RyanP0342
1997 - 2003 F150
May 12, 2019 12:20 AM
HokieHiVPI
Nov 22, 2012 07:15 AM
Tree Doc
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Aug 29, 2010 05:23 PM
cougarmandan
Modular V8 (4.6L, 5.4L)
Aug 6, 2010 08:45 AM
psu1xj
Sep 26, 2007 09:29 AM
