94 e150 5.8 runability issues
Old Feb 2, 2017 | 08:21 PM
jasonb100272's Avatar
jasonb100272
94 e150 5.8 high top conversion only 82k went from 14-15 mpg to 7 replaced all injectors w re man ,fp reg, tps, upper intake gasket . having a rare oil shooting out on passenger side. no coolant in oil or oil in coolant. cleaned side of engine now nothing. clean starts and seems to runs ok but when it is cold there's a whistle at witch goes away when engine gets warm can not seem to find a vacuum leak. going to take it on a 2500 mi trip with 5 kids no engine codes 111 any clues . and the blend door is stuck half way my guess a actuator but where is it? any help or suggestion's please.
thanks jason
Old Feb 3, 2017 | 07:14 PM
Wildman25's Avatar
Wildman25
Little tough to read your short hand.........we don't Tex around here......
Check out this Link, you might find something that lead to the problem.
If you replaced the injectors, did you check the intake manifold for vacuum leaks?? And yea, you need to replace the gasket on the plenum for the injectors.
Have you pulled any plugs and check them?? Check the rotor and cap?
Check the timing? Timing off could kill the mpg's.
Another thing that can kill the mileage is the EGR valve. Link here.
Plugged catalytic converter, that would show up as a lack of power.
Don't quite get this.......'having a rare oil shooting out on passenger side'
Unless the valve cover is leaking, the oil can come out the PVC gasket. This would be noticed on the right back side of the engine.
This can be fixed with a $2 gasket. Is the PVC working or filled with oil??
If the engine has extreme internal pressure, the oil will "blow" out the PVC. Do you have excess oil in the bottom of the air filter??
Old Feb 4, 2017 | 05:41 AM
richter roxs's Avatar
richter roxs
have you checked for fuel leaks in you lines and tank , the gas has to be going some where. the van would not run if that much extra fuel was being injected into the engine
The Terrible Blob
Dec 22, 2013 03:08 PM
mike L
Mar 28, 2008 01:57 PM
rluca
3.8 & 4.2L V6
Apr 10, 2007 07:09 AM
jdimassi
1978 - 1996 Big Bronco
Jan 18, 2004 02:21 PM
mudinford
Dec 24, 2001 02:00 PM
