If you go to Ebay and then search under "truck camper tie downs", then under "used", there is one for sale for $449 right now, but you have to pick it up in Arizona.
Steve
Steve, That ebay one Torklift Superhitch 1999 2015 F250 F350 F450 Ford Trucks No Drilling | eBay is for the Super Duty pickups and is not compatible with the Excursion. Ford's big wagons have a different frame geometry at the rear due to the full body vs pickup bed. If you bolt a SD hitch onto an EX the receiver hole will be pointing down towards the ground at about a 30 degree angle. Aftermarket hitch choices for the mighty EX are more limited than they are for their cousin SD trucks.
But that is a good deal for a truck owner that wants a very strong hitch upgrade over stock!
