How does the Remote Starter work?
Old Feb 2, 2017 | 12:24 PM
BII Plow Truck's Avatar
BII Plow Truck
On Push Button Start trucks when using the remote starter, does the truck require you to re-start the engine once you get in? Or has Ford figured out how to recognize that the guy with the key is sitting right there?
Old Feb 2, 2017 | 12:26 PM
Melansk's Avatar
Melansk
After I remote start mine I get in and hit the button, and I am good to go.
Old Feb 2, 2017 | 12:27 PM
garco61's Avatar
garco61
When you climb into truck, you simply press the start button on the dash and everything unlucks/engages to drive away. Just possessing the key fob is not enough, having the fob is necessary to press start button.
Old Feb 2, 2017 | 01:09 PM
troverman's Avatar
troverman
It works very well. Remote start from the fob. Then put the fob in your pocket. Walk up to your truck, grab the door handle, the door unlocks, and you hop in. Now, simply hit the engine Start button and drive away. You do not even need to hit the brake pedal. Works great. No restarting the engine.
Old Feb 2, 2017 | 03:41 PM
Uzumati's Avatar
Uzumati
Without push button start you just have to cycle the key to run no "re-starting" needed
Old Feb 2, 2017 | 03:48 PM
coolidge54's Avatar
coolidge54
What, after remote starting mine it requires a foot on the brake pedal then hit the start button same as if you were starting normally.
Old Feb 2, 2017 | 06:46 PM
gpf2ez's Avatar
gpf2ez
When I remote start there is no need to touch the brake when I push the button.
Old Feb 2, 2017 | 07:01 PM
motofreek77's Avatar
motofreek77
What he said ^^^
Old Feb 2, 2017 | 07:30 PM
coolidge54's Avatar
coolidge54
Confirmed, I tested this afternoon and no need to apply the brake...but I'm pretty sure I had to once before, weird.
Old Feb 2, 2017 | 10:10 PM
rollerstud98's Avatar
rollerstud98
Probably just habit also need to push brake to put it in gear.
Old Feb 3, 2017 | 03:15 PM
PwerStroke99's Avatar
PwerStroke99
No brake pedal pressing on mine either. mine works just as troverman described
Old Feb 3, 2017 | 04:48 PM
rocket_scientist's Avatar
rocket_scientist
I only ever managed to get mine to remote start one time. The rest of the time the red led on the FOB lights up. I probably am missing something and need to RTFM.
Old Feb 3, 2017 | 04:55 PM
MJ7R77's Avatar
MJ7R77
Starting it and putting it in gear to actually move forward are two different things....The transmission shift unlock is still tied into the brake pedal being depressed.
Old Feb 3, 2017 | 09:02 PM
BII Plow Truck
Thanks all! I wonder why those smart German engineers at Volkswagen couldn't figure it out with their remote start and push button? Our Passat TDI kills the moment you open the door, requiring a re-start. Sheesh! I don't even use it.....thinking what's the point?
Old Feb 3, 2017 | 09:20 PM
mhoefer's Avatar
mhoefer
The system on the 2017 is linked to the passive security so when you get in, it knows your FOB is in your pocket. Then you hit the start button and everything comes up. Away you go. The only thing I don't like is when truck is running and I want to leave it running and get out, the alarm beeps at me, it doesn't like leaving it running. I have yet to figure out if there is a way to set the remote start before I get out so I don't get this double honk warning. But there is always Forscan when I get it to disable the double honk.
On my old truck, you had to unlock the door, and put the key in, change to on, before touching the brake or it would shut off the engine. If you unlocked without the remote, i.e. Door pad, it would set off the alarm and shut off the engine. Then you would need a lock, unlock to clear the alarm, before you could start it with the remote, and if the alarm went off, you would often need to use the restart with the remote or it would not start with the key. So for the TDI, i LED try remote starting it, then I would try unlocking with the remote, putting key in ignition and turn to on, before touching the brake to see if that works. This is a German engineering thing, so worth a try. I know cause I am one.
ezduzit23
General Automotive Discussion
Jan 24, 2014 08:31 AM
HONDAFIXER
Apr 24, 2010 11:17 AM
GRAT
2004 - 2008 F150
Dec 27, 2005 06:44 AM
RockinB
Apr 29, 2005 06:02 PM
kartracer
Escape & Escape Hybrid
Sep 14, 2004 11:35 AM
