351w Header Options
Old Feb 2, 2017 | 08:30 AM
jmm1975's Avatar
jmm1975
351w Header Options
Hey guys..new to this site but not fords. I have a 1982 f100 im working on and im building a 393 stroker to go in it. The only problem is that the largest header primary tubes ive found are 1 5/8". Im gonna need at least 1 3/4" primaries for this engine. Does anyone know of a manufacturer who builds a header with that primary tube diameter or know of any headers from other vehicles that will work? Thanks.
Old Feb 2, 2017 | 08:33 AM
Franklin2's Avatar
Franklin2
Manual transmission or automatic?
Old Feb 2, 2017 | 08:37 AM
jmm1975's Avatar
jmm1975
Aod transmission
Old Feb 2, 2017 | 08:41 AM
Franklin2's Avatar
Franklin2
There is a chance mustang shorty headers will fit, though a custom y-pipe will have to be made. You may need to keep the small header pipes to restrict the power a little bit to keep from blowing up the trans. You must be ordering one of those highly modified high dollar AOD'S?
Old Feb 2, 2017 | 08:48 AM
jmm1975's Avatar
jmm1975
Ive built a few aod's in my time and they hold up pretty well with the right parts installed in them. If i cant get it to hold up ive got a built c4 i can throw in there but i like to get out and drive it to the track. Im not a fan of trailer queens lol
Old Feb 2, 2017 | 08:55 AM
Franklin2's Avatar
Franklin2
Like I said, I found a few threads where truck guys have gotten 5.0 mustang headers to fit. But if you find the large tube headers who knows.
I have heard the hollow shaft they use for direct drive and also send oil pressure through the middle of it to lock the converter up is the weak link. Is that true?
Old Feb 2, 2017 | 08:59 AM
jmm1975's Avatar
jmm1975
The direct drive input is the one that breaks. Its the small shaft that goes inside the main shaft. The fix is a one piece shaft but u lose the lock up capabilities and fuel mileage suffers
Old Feb 2, 2017 | 09:03 AM
Franklin2's Avatar
Franklin2
So in the lower gears when it's not locked up it's ok? Only if you horse around with it in overdrive with the converter locked up?
Old Feb 2, 2017 | 09:53 AM
jmm1975's Avatar
jmm1975
It locks up in drive and overdrive.
Old Feb 2, 2017 | 04:47 PM
big ole ford's Avatar
big ole ford
I have had extremely good luck with flowtech headers as far as performance goes, I cannot attest to their durability because I usually dont keep a vehicle long but I do know I was impressed enough with them on the 351ho in my 85 f250 I bought another set when I replaced the 351 with a 460.
dwcford
27
May 30, 2016 11:56 AM
Bluebandit!
Jan 10, 2016 08:17 PM
79_FORD_F-100
May 14, 2014 10:49 PM
AstroFab
Nov 16, 2011 07:13 PM
70T351W
Jun 12, 2006 09:54 PM
