Seat Swap Question
Old Feb 1, 2017 | 05:30 PM
knightmare_1989's Avatar
knightmare_1989
Seat Swap Question
I am looking for info and pictures if possible of anyone who has installed newer seats into there dentside.
I want to use a set of 2008-13 Harley F-150 seats due to style, comfort, and color scheme. I included a picture similar to the seats I want to purchase.
Old Feb 1, 2017 | 07:07 PM
fordguy2100's Avatar
fordguy2100
I know newer super duty rear benches bolt in place of reg cab benches so I'm sure those will work but may require some modification
Old Mar 22, 2017 | 03:46 PM
eb76adam's Avatar
eb76adam
Beware - Measure the height of the seats from the lowest mounting point to the seat surface and compare to the stock seats.
Most of the later seats that have electric motors underneath sit much higher.
I just finished putting in Lariat Leather seats in the front of my CC and my head is about 2 inches from the ceiling. I'm 6'.
I fabbed brackets to sit them as low as possible and they are still much taller than stock due to the electronics underneath.
Think I'm going to have to put these in my EB and go back to a recovered bench in the CC.
If you want to ditch all the electric stuff you should be able to unbolt them from the late model brackets and put them on a stock(ish) slider and just get the basic functions.
Old Mar 22, 2017 | 04:15 PM
jakeharp's Avatar
jakeharp
Some fabing
I just took a set of buckets out of mine and put an original vinyl bench seat back in .... And I can tell you that the buckets had a custom bracket welded up to match the drop off you get on the floor towards the doors.... So im sure you will have to fab up a similar matching elevation bracket of some kind....... Would be nice to keep the electronics on those Harley seats tho....... Hell if your gonna go thru the potential PITA of putting them in ...Post some pics when your all done, prolly look pretty bad A $$
muddrcr4
May 31, 2013 02:05 PM
ggrindstaff
Feb 23, 2008 11:59 AM
V10KLZZ71S
Jun 18, 2004 08:19 AM
Sycostang67
May 21, 2003 04:39 PM
shawngp
Feb 16, 2002 03:22 PM
