2000 Excursion 4wd 17" wheels fit??
Old Feb 1, 2017 | 11:09 AM
Irish19614x4's Avatar
Irish19614x4
Looking to get a set of cheap 17" wheels just for temporary reasons.
Looking at this ad the seller said he tried to put on a 4wd but didn't fit. Is this because it will need the spacers in the front?
I wanted to take my 17" tires off my F350 mount them on our Excursion and put 35" tires on the F350.
This would be temporary until I source better looking wheels. My tires on my F350 KO2s are brand new and it's DRW so I will have two spares for the Excursion.
Will these fit?
https://seattle.craigslist.org/kit/wto/5979219801.html
Old Feb 1, 2017 | 01:34 PM
WE3ZS's Avatar
WE3ZS
Any OEM 17" wheel will be from '05+ on the SD pickups, so spacers/adapters will be needed to correctly position the tires under the EX.
Old Feb 1, 2017 | 03:22 PM
Irish19614x4
Okay but they will work is what I'm looking for. Im trying to snag them up but the guy isn't answering right now.
Old Feb 1, 2017 | 03:29 PM
WE3ZS's Avatar
WE3ZS
Well, yeah, they will bolt up and you could drive with them. Just expect to have some tire rub on the front leaf springs and the tires will sit about 2" in towards the truck's centerline more than the correct wheels would have them.
Old Feb 1, 2017 | 03:33 PM
WE3ZS's Avatar
WE3ZS
Unrelated to any particular item listed here but why do some of these links to CL show up as clickable links and others have to copy and pasted to get to the ad?
Is everyone else seeing the same mix of direct links and just plain text that needs to be C&P'ed, or is it just something my work computer is doing to the links?
Irish19614x4
But if I run 2" spacers it will fix that?
Old Feb 1, 2017 | 04:53 PM
StreamOn's Avatar
StreamOn
Tom - I am seeing the links the same way you are.
Old Feb 1, 2017 | 05:01 PM
mecdac's Avatar
mecdac
Yes, and a good set of spaces/adapters will cost more than the rims and tires, in most cases.
Old Feb 1, 2017 | 05:16 PM
unleashd's Avatar
unleashd
Tom
I see it the same way that you do. Some clickable, others aren't. IIRC, there is an option in your profile to automatically parse URLs. If that is checked, it shows the post as clickable.
Old Feb 2, 2017 | 05:51 AM
WE3ZS's Avatar
WE3ZS
Yes, 2" HUBCENTRIC spacers will fix the tires/wheels to the correct location under the EX. And like Mark said, some of the spacers options will cost more than the wheels (and tires in some cases), There are some cheaper ones other than the time tested steel and aluminum offerings from Fred but do some research if shopping for the more affordable ones, a lot is riding on them.
Old Feb 2, 2017 | 07:16 PM
Misky6.0's Avatar
Misky6.0
When pasting a weblink, hit ENTER to move to the next line, the weblink becomes clic able. If you type space and keep typing it isn't clic-able.
Same thing in word documents, email, facebook posts, etc.
Stevekron1
Sep 27, 2015 09:46 AM
doc0812
Aug 27, 2013 01:09 PM
kameronth
Oct 9, 2011 04:22 PM
PartsKen
May 9, 2011 12:13 PM
f-1501988
2009 - 2014 F150
Mar 25, 2010 03:23 PM
