I'm about to clean and seal the inside of my mid-ship (Aux) fuel tank. 69 F250 Camper Special, original engine was a 360. Does anyone have the sending unit and the gasket part numbers. My sending unit may be still good, but I'll need the gasket for certain. Thanks in advance. Still fighting the rust, cause Bump Lives Matter!
Well, 1st off the o-ring seal and a new float are both still available from Ford. The o-ring is part number C0AF9276A. And the float is C0AZ9202B.
68/69 F100/350 aux. under cab tank was part number C8TZ9275A. This was replaced by kit part number D0TZ9275D. This kit included the sender, o-ring, and an adaptor hose because it's hose nipple was a different size. MPH found this out recently. He can expand farther, but I believe he was trying aftermarket.
Green Sales
(800) 543-4959
Shows as having both the C8TZ9275A and the D0TZ9275D.
x**************************
*************************** Nos Parts Source *Fo
Mrpotatohead it has 5/16 line. Thanks Jefffafa, I'll post that info in my truck file. If it warms up today, Ill clean the outside of the tank, then remove the sending unit and take a look inside.
Yes but Mrpotatoehead found that that one had a 3/8" nipple and no adaptor hose in it rather than the 5/16" that the truck has. So I discounted posting it.
