Anyone know the casting numbers for the factory exhaust manifolds on a 65 F100 4x4? I have a set of old headers on now and want to find a set of manifolds in case my high pinion axle interferes with the headers when I go to install it. There are so many different ones out there I want to be sure I get the correct set for a 65 352 FE in a 4x4
2WD/4WD makes no difference / Ford part numbers:
D0TZ-9430-A (replaced C5TZ-9430-A) .. Right Exhaust Manifold / Obsolete
1965/67 F100/350 352 / 1968/76 F100/350 360/390.
C5TZ-9431-A .. Left Exhaust Manifold-Use with heat riser valve / Obsolete
1965/67 F100/350 352 / 1973/74 F100 360.
If the heat riser valve is no longer present:
C8TZ-9431-B .. Left Exhaust Manifold-Use without heat riser valve / Obsolete
If you have to go back to manifolds (I would never recommend it) try and find a ribbed driver's side manifold off of a '75 or '76 as they flow better than the early ones. All of the passenger side truck manifolds flow horrible.
