Tie Rod Ends???
Old Jan 30, 2017 | 10:08 PM
seagiant's Avatar
seagiant
Tie Rod Ends???
Hi,
Wondering who has the best tie rod assemblys for my....
89 F-150 2WD pick-up???
After market, OEM, which way to go on this??? Thanks!
Old Jan 30, 2017 | 10:47 PM
timbersteel's Avatar
timbersteel
I always purchase MOOG for steering components.
And if you purchase from RockAuto, way cheaper than the parts store.
Old Jan 30, 2017 | 11:38 PM
Bootlegger's Deluxe's Avatar
Bootlegger's Deluxe
I second the suggestion for MOOG steering and suspension components. Its what I install at my job as an undercar tech. They offer a lifetime warranty, they typically come with an improved design over the factory component, giving them a longer life and less wear over a stock replacement.
I have bought them both at a local parts store and on Rock Auto, I have never had to warranty one out through rock auto, but that would be my only concern with buying online. it typically is cheaper, just make sure to factor in shipping costs while comparing prices.
Old Jan 31, 2017 | 04:36 AM
My4Fordtrucks's Avatar
My4Fordtrucks
I have had to warranty or just send back/exchange parts through Rock Auto. Very good customer service.
Moog steering and suspension parts are good quality. Can't go wrong with Motorcraft parts either.
Old Jan 31, 2017 | 05:48 AM
seagiant's Avatar
seagiant
Hi,
Thanks Fellas!
I'll look into that!
I "assume" Duralast at Auto Zone is CHINA?
I wanted to do better than that, all though, they may be fine?
Old Jan 31, 2017 | 08:07 AM
Bootlegger's Deluxe
yes, duralast, along with almost every other "house brand" steering and suspension components are made overseas. I cant verify that it's china, but overseas.
if for some reason Moog ended up being unavailable, my second choice would be TRW suspension parts. But I still hold Moog as the top choice.
Old Jan 31, 2017 | 10:20 AM
seagiant's Avatar
seagiant
Hi,
Thank's Bootlegger!
I'll go MOOG!
I don't want any "stupid" problems down the road!!!
Old Jan 31, 2017 | 11:26 AM
Bootlegger's Deluxe
Call me Boot
If you are replacing all of the tie rods, I would suggest investing in adjuster sleeves ascwell. the person doing your alignment will thank you, and you will have a much better time with assembly.
Old Jan 31, 2017 | 12:33 PM
GoinBoarding's Avatar
GoinBoarding
Moog is not exclusively US built. Far from it actually: Where are Moog parts made? The answer may surprise you! - Suspension.com . They are high quality parts regardless.
Old Jan 31, 2017 | 04:14 PM
seagiant's Avatar
seagiant
Hi,
Thanks, very interesting!
As my truck is an 1989, I don't even think I can get OEM from a Dealer (to old?)
Moog might be the best way I can go?
No matter where it is made?
Old Jan 31, 2017 | 04:31 PM
My4Fordtrucks
Motorcraft parts are available from places other then the dealer.
Old Jan 31, 2017 | 05:02 PM
seagiant's Avatar
seagiant
Hi,
Hmmm....so you are keeping "where" to yourself?
Old Jan 31, 2017 | 05:48 PM
Bootlegger's Deluxe
Rockauto sells motorcraft. certain chain stores carry motorcraft parts, or can order them in as well.
I have found out that certain motorcraft parts are superior (the one that sticks in my mind is the track bar ball joint on 2009-ish F 250s ) but more often than not, the parts are not greasable ( cant recall if the particular parts for your truck are or not) and don't carry a lifetime warranty.
Most Moog parts are not made in the USA, that is true. Sadly, its a way of the world, with its worldwide economy, nowadays. I still stand with my previous statement, Moog steering and suspension parts are what I install onto customer cars, and onto my personal trucks as well, they tend to be the best value for your money.
Old Jan 31, 2017 | 07:19 PM
seagiant's Avatar
seagiant
Hi,
Thanks, I appreciate it.
I know I can get MOOG local probably from a Mom/Pop Store I know!
Might have to be ordered but I rather buy local and have that connection!
Thanks again!!!
F350-6
24
Jan 8, 2015 05:08 PM
montanacw
6.7L Power Stroke Diesel
Mar 7, 2013 08:02 PM
sum_weirdo
Jun 17, 2011 11:27 AM
jeff351
Aug 13, 2008 08:37 AM
LARIAT 85
Dec 14, 2007 03:15 PM
