another one down .. 218 miles
Old Jan 30, 2017 | 05:37 PM
FOUNTAIN 1's Avatar
FOUNTAIN 1
well there you go . more bad news on our trucks .. 218 miles locked up motor / oil problem I'm guessing . boy read on his facebook .. good news travels fast ...
Old Jan 30, 2017 | 07:05 PM
Dustinmr22's Avatar
Dustinmr22
Seen that as well. I'm just glad to see the ones with oil pump problems are dropping out fairly quick. Makes me feel better about mine as i turn over 16k miles and only had the trans line leak so far.
Old Jan 30, 2017 | 11:57 PM
kry226's Avatar
kry226
Which Facebook page?
Old Jan 31, 2017 | 01:02 AM
Chris Crews's Avatar
Chris Crews
Is it myth or true that buying first year remodel is a bad idea? Because they have kinks like this to work out or is it just luck of the draw
Old Jan 31, 2017 | 04:13 AM
Rheingar's Avatar
Rheingar
Typically this applies when there are major engine or transmission changes. There were some changes to the motor, but nothing major and nothing to do with oil (that I know of).The question here is did the oil pump change with the redesign? If it did not, this problem would have happened regardless of the redesign.
Old Jan 31, 2017 | 06:18 AM
Strokin-A-2010's Avatar
Strokin-A-2010
Ford has always put crappy oil pump and oil pump gears in their engines. Especially the 5.0 and now the 5.2. So it would wouldn't surprise me one bit they went the cheap route on the 6.7 as well.
Old Jan 31, 2017 | 06:19 AM
T diesel's Avatar
T diesel
Man that's awful.
Old Jan 31, 2017 | 06:22 AM
troverman's Avatar
troverman
This is completely unsubstantiated. We had a 2011 F-150 5.0 which went 60,000 entirely trouble free miles. That engine was smooth as silk. I know several owners of 5.0L Mustangs (Coyote engine) with more miles than that; no issues.
My 2017 has 5,000 miles on it with zero issues except the media door.
Old Jan 31, 2017 | 06:40 AM
Strokin-A-2010
I guess I wasn't clear with my post, sorry. On the coyote engine the oil pump gear is the weakest link when modding especially when you add boost that's why people switch to a billet oil pump gear. But there are severely GT350 owners that are bone stock that the oil pump gears went out on them. Ford knows its a problem but doesn't fix it and continue to use the cheap oil pump gears.
Old Jan 31, 2017 | 06:41 AM
jschira's Avatar
jschira
I have to agree with Troverman. I have never heard this before.
The oil pump is designed to handle the stock engine as it leaves the factory.
I do not think that you can you can add an aftermarket blower and/or other high performance mods then complain that the stock engine components are weak.
Old Jan 31, 2017 | 06:44 AM
Strokin-A-2010
Read my post above yours.
Old Jan 31, 2017 | 06:45 AM
fordmantpw's Avatar
fordmantpw
FYI, the pump being the weakest link when modding really has nothing to do with Ford using a cheap pump. It's built to handle stock numbers, and that's all that matters.
The GT350 is another story if what you are saying is true.
Old Jan 31, 2017 | 06:47 AM
Strokin-A-2010
When people buy a mustang do you really think they will keep it stock? lol And yes I'm a member on a few GT350 forums and facebook group and it is a known problem. And a friend of mine has a GT350R has 1100 miles on it bone stock and had a new engine replaced cause the oil pump gear went out. I don't think its the power is the issue with the 5.2L its how high the red line is on that engine.
Old Jan 31, 2017 | 07:01 AM
fordmantpw's Avatar
fordmantpw
But that's not Ford's problem. And I would wager that most Mustangs are stock (engine-wise). Just like most Super Duty trucks are kept stock. What you see on fan forums is not the norm.
Old Jan 31, 2017 | 07:06 AM
17450KR's Avatar
17450KR
In only thirteen posts we go from a SD 6.7L Diesel Oil issue to a modified Mustang with upgraded billet oil pump gears...that has to be a record!!
Back on topic: Grab your umbrellas...the sky is falling again.
