300 strait 6 question
Old Jan 30, 2017 | 07:54 AM
83sd's Avatar
83sd
Found a guy locally that has a good running 300 in a 78 custom. He is parting the truck out. Guy wants $450 if I pull it. Engine is still in the truck and able to be test run. I was thinking of hearing it run and once warm, doing a quick compression test. If its in as good of shape as he says, it should save me some $$$ over rebuilding mine.
Main question is, did anything change between 76 and 78? It currently has an auto bolted to it and I will need to bolt my 4 speed up. Were there any differences besides the bell housing and a flex plate on the autos? I should be able to install my flywheel and clutch assembly with no issue, correct?
Thanks in advance, hopefully going to look at it this week and possibly talk him down a little.
Old Jan 30, 2017 | 01:19 PM
meangreen92's Avatar
meangreen92
It should be compatible. Keep your truck's original shim-plate between the engine and bellhousing. That piece always goes with the transmission. There might be a different EGR/carb spacer, but you can just swap everything, or anything different, over from your original engine. Also look to see if the donor has a smog pump. If it does and yours doesn't, then it's still not a big deal, but could require a threaded plug somewhere - although I must state that I'm not familiar with the smog pump/Thermactor setup on the 300s, but if we were talking about a 302, then you would need two bolts or plugs to thread into the back of each cylinder head...
Pics of the two engines would be good.
royster69
19
Oct 3, 2014 10:14 PM
broncoman66
Large Truck
May 9, 2012 08:22 AM
homesteader4
Nov 9, 2011 07:53 PM
Ford_By_Four
Dec 15, 2004 12:19 AM
ROTCJS
Mar 9, 2003 12:19 AM
