Tires
Old Jan 29, 2017 | 10:31 PM
maxtor's Avatar
maxtor
Tires
We have a 2012 F250 6.7 psd all stock. We have 14,754 miles on it.
It has the original tires and wheels. It is a 2wd with posi.
If it sniffs mud, the rear tires spin. Posi engaged or not. The tire grooves fill up with mud, and we slip and slide.
What tire do you guys recommend. 99% of our driving is highway pulling a 5th wheel. Our tires are 17inch all season.
Old Jan 29, 2017 | 11:52 PM
Dakster's Avatar
Dakster
Anything but the stock Michelin M + S tires... Trying to decide my next set of tires now, since I have 16k on the clock and mine will be done by next winter.
Old Jan 30, 2017 | 04:10 AM
golfmedik's Avatar
golfmedik
Lots of people around here run the Firestone Transforce H/T or A/Ts. Usually the HT on 2WD and AT on 4WD, but that is just a popular tire for our area. Not many tires(street) are going to do well in mud or on slick surfaces due to the closeness of the tire lugs. The more you space them out, the more aggressive the tire becomes as it is able to self clean more effectively. That being said, the more widen them, the less quiet they are and the more prone to cupping they become. Cooper tires have become the #1 replacement tire in the US, but lots on here don't have good things to say about them. If you want a more aggressive style tire try Nitto Terra Grappler or the Dura Grappler. Toyo tires is who makes the Nittos and have several good designs themselves on their "Open Country" line of tires.
There are many different brands and tread designs out there. You stated that most of the time the truck is pulling a 5er on pavement, so I would look more towards a great highway tire. They will usually give you better mileage than the all terrain tires, but any of the few above should get you close to the same mileage if they area kept aired up and rotated.
Old Jan 30, 2017 | 09:56 AM
LabCab's Avatar
LabCab
For a 2 wheel drive truck you will need a more aggressive tread for the rear. I put BFG TAKO on my 4x4 F350 and they keep me out of trouble when I get into the mud hunting. They are still quiet on the road and I am happy all around with them.
Pat
Old Jan 30, 2017 | 10:12 AM
maxtor's Avatar
maxtor
Thanks, I will check each of them out;
Our truck does not see "dirt or mud" very often, but when I need to hook up our car trailer to transport our race car, and if the ground is not completely dry, the tires will spin.
Old Jan 30, 2017 | 02:33 PM
'65Ford's Avatar
'65Ford
Good luck to you, OP. I have fairly aggressive mud tires on the back of my 2002 3/4 ton extended cab diesel (locking rear) as well as the back of my '65 3/4 ton (open rear)...both trucks are 2wd. The '65 gets around better in the squishy sod than the 2002 when empty. My theory on the difference is the diesel is so dang heavy in the front. The '65 is darn near equal weight front and back based on its empty weight on a CAT scale. When loaded heavy, the diesel does better due to the locking rear.
Old Jan 30, 2017 | 06:46 PM
Superduty450's Avatar
Superduty450
Nitto Tires are not made by Toyo; they are made by Nitto Tire and Rubber.
Old Jan 30, 2017 | 08:30 PM
golfmedik's Avatar
golfmedik
With a Billion Dollar Goal, Nitto Retains the 'Underdog' Role - Tire Review Magazine
Old Jan 31, 2017 | 08:35 AM
Superduty450
apparently the info I was reading online is incorrect or yours is, can't always believe whats online. I do know that Nitto does not offer a tread life warranty (duragrapplers) any more because my son just found when his tires failed with just under half tread, running Coopers now.
Old Jan 31, 2017 | 01:28 PM
senix's Avatar
senix
I have always had a preference for Cooper Tires. Mine (OEM BFG) are getting close to being replaced.
So I am starting to look and see what I can run with a DRW.
Old Jan 31, 2017 | 03:21 PM
jfralph's Avatar
jfralph
apparently someone should read the article in tire review mag. Nitto is indeed owned by Toyo. They probably have separate tire plants, but in the article, toyo supplies the raw materials for nitto.
have a nice day!
crstewart60
Mar 29, 2011 05:06 PM
SuperBlue
Jan 11, 2006 01:32 PM
dcale101
1983 - 2012 Ranger & B-Series
Oct 7, 2004 02:24 PM
78f250
Aug 17, 2001 04:46 PM
