wondering about putting E4OD in my 79 f150
Hey guys, New to the forum and new to ford trucks. I picked up a 79 freewheelin Ford f150 from a friend. I have a 351M that I'm rebuilding right now and would like to put an overdrive transmission in it, I've read a little bit on it. I'm wondering if I the donor truck I found would have the majority of the parts to complete the build. I found a 92 f250 with a 460 (big block bell housing) it's 4x4 so I don't have to wonder if my old transfer case would bolt up as it already has one. I also know I'll need a controller for that trans. I'm wondering what needs to be done to make the shifter lever work, does the floor pan/trans hump need to be modified, does a crossmember need to be made or will a certain year work, do I need to clock the transfer case different and how is this done, will the torque converter bolt up to a 351m flex plate? Thanks for any help
Just connect it. It will work without modification.
I don't know the answers to any of your other questions.
Yes, that's true. The E4OD is longer than a C6.
US shift makes standalone controllers. Shift linkage can be made to work with some sort of adapter. If u have a 4wd you should already have the tall transmission hump to clear.
I'm working on the project for my 77 2wd over the next few years. I've also acquired a 460 trans. You also need to figure out a speed sensor and how to run the speedo. My trans is older so has the gear driven VSS/ speedo cable combo
I can't answer that for sure. When I read the original post I thought he was planning on using the original NP205 behind the E4OD, but I may have misunderstood.
fiftyfordfloored
19
07-03-2014 10:56 AM
wookbigalow
02-25-2010 10:52 PM
bigperm2
07-29-2006 08:05 PM
hokeyson
07-09-2002 09:55 PM
