transfer case fluid
Old Jan 29, 2017 | 09:20 AM
hotrodfeguy's Avatar
hotrodfeguy
transfer case fluid
How often do you all change your Transfer case fluid? Also what weight do you guys use or does every one stick with the ATF/Merc5 stuff?
Old Jan 29, 2017 | 09:36 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I changed mine when I bought the truck 2.5 years ago with Amasoil Synthetic ATF. Some have moved away from the ATF and gone to a specific transfer case fluid recommended by Ford.
I don't plan to change it very often, perhaps during transmission fluid changes, which I have a manual so about every 25K miles or so based on use.
Old Jan 29, 2017 | 10:23 AM
mueckster's Avatar
mueckster
I started using Mobil 1 Synthetic ATF in my transfer case when rebuilding my "mechanical diode" 4R100 about 9 years ago. It was changed out at each trans service, there after (~ 50k miles). I also serviced my ESOF locking hubs at that time. ~ 150k miles using the Mobil 1 and no issues.
Old Jan 29, 2017 | 11:00 AM
TerranE's Avatar
TerranE
Due to the reported changes in ATF formulations, I used the recommended Ford transfer case fluid.
I figure that first it only takes a couple of quarts and secondly it only takes a couple minutes to change. Any warm fuzzy feeling I get from using synthetics can be regained by changing before the recommended interval. Any money saved by using a cheaper blend of ATF is minimal.
Old Jan 29, 2017 | 11:25 AM
Pitcrw6's Avatar
Pitcrw6
Yeah Ford issued a service bulletin not to use Mercon V and said to use a special transfer case fluid. XL-12.
Old Jan 29, 2017 | 01:41 PM
donnybrasco's Avatar
donnybrasco
^^What pitcrw6 said.
CLICK HERE.
I'm currently using Mobil 1 ATF. I will eventually flush the transfer case again soon.
johnnyrocket
Jan 8, 2010 02:39 AM
PsD007.3
Feb 3, 2009 04:47 PM
wipper
Sep 26, 2007 12:57 AM
crazylewi
Oct 30, 2006 07:12 PM
bug juice
18
Oct 16, 2005 12:01 AM
