transmission issue
Old Jan 27, 2017 | 12:52 PM
efeaganes93's Avatar
efeaganes93
transmission issue
I have a 2004 F250 I just had a Ford transmission out in it. when the truck is cold it runs great. buy when it gets warm it gets stuck in a gear, even if I drop it into a lower gear. Also, if I cut it off when this happens and i cut it off it will not turn over as if it's not in gear, in park or neutral, but if I let it sit for about 20 minutes it will turn over and run as it should until it warms up again.
Old Jan 27, 2017 | 02:18 PM
seijirou's Avatar
seijirou
Did you put in the trans or someone else? If someone else I would take it back.
WarriorDog
Dec 12, 2024 06:32 AM
KenKl
Oct 19, 2016 11:15 AM
DZL JIM
Sep 2, 2010 07:02 AM
fcfirefighter05
Jan 30, 2007 01:15 PM
