Engine swap questions - from 215 to 352
I'm looking to swap the 215/T98 out of my '53 for a 352 and 4 speed manual from a '66 F100.
I've found the crossmember and mounts for the engine swap, but I'm unsure about the transmission mounting. Is the T-18/19 in the '66 close enough in size to the T98 to use the stock crossmember with a little modification? Or will I need a completely new setup? (I know TransDapt makes universal trans crossmembers but I don't know if I'll need one with no drop, or some sort of drop to maintain the pinion angle.)
Also, I know a new radiator is in order, but the current one is leaking badly, so a replacement is already in the budget.
Any other obstacles to making this swap a smooth one?
TIA
TIA
I didn't know about the clutch linkage, so thanks for that info. Just something else to think about...
Received 1,353 Likes
on
on
you can do this and avoid all the guessing
http://jniolon.classicpickup.com/tra...ember/tcm.html
later
John
later
John
I'm supposed to make the 4 hour round trip, plus some time to help the guy pull the engine, on Thursday.
@Fomoko1, @jniolon - thanks for that info.
Austins70F100
06-21-2011 03:44 PM
