The axle seal is bad on my 93 Explorer, manual, 4x4 both sides. The shocks and leaf springs are also shot. Instead of replacing the seals, was advised to just replace the entire axle and pick one up at the boneyard with springs.
I am wondering what axles from other vehicles will work? I have been able to find this before through RockAuto's website but there is no information concerning rear axle. Is there a source showing interchangeable parts between vehicles? Aside from the body, Explorer is basically rebuilt now, just needs the gearbox replaced.
Plug in your info and it will show you results from other models that interchange, if a yard in you area has it. You could expand your search area to get more hits. Any junkyard worth a darn should be able to tell you what interchanges.
