Ford 8.8 Rear Axle Assembly - Differences
Old Jun 6, 2009 | 01:04 PM
cher96's Avatar
cher96
I have a '99 Ford Explorer 4x4 with a V8 and a F8.8 Rear End that needs replacement. I have been unable to find a used one with 4.10s or even any F8.8 that is supposed to be swappable into an Explorer with a V8 here in Tampa, Florida. The Yards here tell me that a F8.8 out of a V6 Explorer will not work. Is that true and what are the differences between the two Assemblies?
Thanks
Old Jun 6, 2009 | 02:03 PM
cher96's Avatar
cher96
I'm not a Mechanic... just a Shade Tree Driveway Enthusiast. I appreciate the help.
Would I be able to switch in a Mountaineers 8.8 made for a V8?
Are there any other Rear Axle Assemblies that would work for me?
I still need it to have 4.10 Gearing.
Thanks
Old Jun 6, 2009 | 02:35 PM
Conanski's Avatar
Conanski
The Explorer and Mountaineer are the same vehicle just different dress, so yes that would be a direct swap. What is wrong with your existing axle that the whole thing has to be replaced?
Old Jun 6, 2009 | 02:43 PM
cher96's Avatar
cher96
Would you happen to know the Differences between a V6's and a V8's F8.8?
I need to replace my F8.8 Axle Assembly because of Bent Axle Tubes. I should have Trussed it. I am an avid OffRoader.
I have a '96 Jeep XJ that my son and I have Built. We thought we would try and take the Ford through it's paces. Oh, well. What can I say?
Old Jun 7, 2009 | 12:29 AM
cher96's Avatar
cher96
Anyone know if a Explorer Sport Trac Rear F8.8 will go into a 1999 Ford Explorer 4dr Limited 4WD with a V8?
Thanks
Old Jun 7, 2009 | 04:16 PM
cher96's Avatar
cher96
Front Suspension Classification Independent
Front Spring Type Torsion bar
Front Stabilizer Bar Regular
Rear Suspension Classification Rigid axle
Rear Spring Type Leaf
I have a '99 Ford Explorer 4x4 with a 5.0 V8 and a F8.8 4.10 Rear End that needs replacement. An Axle out of a V6 is not supposed to work for the V8 Explorer according to the Junk Yards I contacted.
It has been suggested that a Sport Trac may or may not work. Anyone have experience with this issue or in the know? What options do I have?
Thanks
Old Jun 7, 2009 | 10:01 PM
steve(ill)'s Avatar
steve(ill)
i dont know the answer, but if its a 4.10 ratio, any axle will mechanically work. the physical differences between axles i dont know. why not stop by the junk yard and have them show you why it wont work? how hard can it be to modify something to fit? maybe its not a big change?
Old Jun 8, 2009 | 12:01 PM
5.0B2's Avatar
5.0B2
If the problem is jusu the bent axle tubes, any F8.8 Explorer/Mountaineer rigid rear axle HOUSING will work - you can swap your components (even your disk brake assemblies) into it. It may be easier if you stay with the ones that are already disk brake equipped.
If you are not comfortable setting up the ring and pinion, get one with 4.10's and swap the entire assembly - the only difference I can imagine is that there MAY be a different driveline yoke on the V6's. In that case you will need to swap the yoke from your V8 unit to it.
unilover6163
May 29, 2017 08:47 AM
fordiesel69
2004 - 2008 F150
Dec 15, 2016 04:33 PM
dferrell5
30
Jan 25, 2014 01:26 PM
Waylon Fan
16
Sep 1, 2012 02:11 PM
oldiron73
Dec 14, 2010 12:12 PM
