Ebrake Caliper Options?
Old Jan 25, 2017 | 06:21 PM
F-250 restorer's Avatar
F-250 restorer
What choices do I have besides the TSM (Caddy)or Caddy calipers?
I wonder if running the ebrake cable through a couple of pulleys on either side would add torque/force, the way a compound bow works, to the piston, thereby clamping harder the pads to the rotor, with the Caddy calipers.
I know about the inline locks.
Old Jan 25, 2017 | 06:54 PM
77fummins's Avatar
77fummins
I haven't done a disc brake conversion... but I did look at it.
Wilwood makes a combination caliper that would be worth taking a look at. Also they have dedicated mechanical calipers which you could mount as parking brake - might get away with only one side.
Your idea on the pulleys is an interesting one. I think you would have an issue getting enough travel out of the parking brake pedal to make it work though.
Old Jan 25, 2017 | 07:27 PM
highway90's Avatar
highway90
I plan to buy the following calipers from RockAuto.com this week. I will reuse the factory e-brake cables. Hopefully this will work out.
Years ago I did a drum to disc conversion using the brackets only from Greatlake Offroad. Then bought the non e-brake calipers. They worked.
Looks like Greatlake has improved and they now have a whole kit you can buy..
Link to GreatLake Offroad product: Ford Dana 60 Full Disk Brake Kit
A-1 Cardone Part #184138, $41.79 and Part# 184139, $41.79
Old Jan 25, 2017 | 07:29 PM
highway90's Avatar
highway90
I tried the line locks with my front F-250 calipers. Never could get it to really hold big 37" tires.. Kinda a waste for me. Plus it wasn't the safest option..
Old Jan 25, 2017 | 07:30 PM
ubereal2's Avatar
ubereal2
If you want to use a disc brake set up, just do this, a drive shaft bake
http://highangledriveline.com/
Unk Bob
Old Jan 25, 2017 | 07:53 PM
highway90's Avatar
highway90
Transfer case E-brake is another good option.
Question: Which holds better?
a) caddy calipers
b) driveline e-brake
I am curious. I live in West Virginia. Lots of hills, hollers, steep roads. Parking brake is critical here..
Old Jan 25, 2017 | 07:55 PM
ubereal2's Avatar
ubereal2
These drive line brakes are what's used in large trucks like box trucks that don't have air brakes.
Unk Bob
Old Jan 26, 2017 | 07:39 AM
77fummins's Avatar
77fummins
The driveshaft brake is far stronger as it has the mechanical advantage of the rear axle.
On my truck i have a slip yoke on the transfer case so I'm not sure how easy it would be to set this up.
Old Jan 26, 2017 | 08:43 AM
Aaron-71's Avatar
Aaron-71
I would avoid these calipers to be honest. After countless hours of research, I came to the conclusion that it's not worth it.
So many countless threads saying "it works great" without pictures, any follow-up, nothing...
If you do end up doing this conversion, post up a detailed thread with lots of pictures and lots of info.
Nobody else has really been able to do that yet it seems.
Old Jan 26, 2017 | 08:57 AM
lafermedavid's Avatar
lafermedavid
I just picked up NWF transfer /case rotor brake,Ill post some picks once its installed,,,np205 manual trans
Old Jan 26, 2017 | 09:04 AM
Aaron-71's Avatar
Aaron-71
A thread on this would be great as well.
I've read some good things about the NP205 e-brake, but it also has it's downfalls.
On my build, I am going to continue to search for an option to have an e-brake mounted in roughly the stock location.
Old Jan 26, 2017 | 10:04 PM
highway90's Avatar
highway90
I just spent 1 hour reading all sorts of bad reviews on the caddy caliper e-brake option.. I think now I will skip this and just go for the transfer case brake option. I have been running the non-ebrake calipers for years, but I have also gone with an e-brake.. Also, see my photo.. as you can see, my caliper are up high, so brake cables would be a mess..
The gear reduction force advantage allows some powerful e-brake power when stopping at the t-case.
Old Jan 27, 2017 | 08:16 AM
Aaron-71's Avatar
Aaron-71
Were most of them written by me? LOL.
I wish I would have bought the caddy calipers, installed them, and then wrote up a massive review on them to help prevent others from going down that road.
Having to adjust your e-brake cables every X kms just seems like a chore nobody should ever have to do.
Post a detailed write-up!!!
My caliper upgrade is the exact same. High mount on the rear side.
Unless you live in the mountains or tow a lot, e-brakes aren't really needed (except for you US guys who have inspections to license).
Careful with the t-case brake tho too. One good kick/bump of the t-case shifter (N) and you'll see your rig roll down a hill in short order.
Old Jan 31, 2017 | 08:42 AM
77fummins's Avatar
77fummins
A transfercase brake hold the driveshaft behind the t-case so it shouldn't matter if it is in gear or neutral. Should still hold fine.
Old Jan 31, 2017 | 08:51 AM
78 PEB's Avatar
78 PEB
I have a Tcase mounted driveline E brake on my '97 F-Superduty Quigley....................Quigley welded the mount on to the TC housing to utilize the OEM
F-Superduty park brake......it works good.....
