Sponsored by: Real Truck
Adding Cruise Control?
Old Jan 24, 2017 | 09:36 PM
thomabb's Avatar
thomabb
The latest addition to the driveway (2012 F250 XL 6.2) is getting ready to be geared up for it's tour of duty. The one thing that was on the would-be-nice but not must-have list was cruise control. This truck doesn't have it, which wasn't a deal breaker because the truck was way inside my budget.
So anyways, while researching hitches, tonneau covers, steps, etc. I came across this;
https://accessories.ford.com/electro...d-control.html
A Ford speed control kit for my truck for $165! Is this all I need to install the speed control? I would assume the dealer would have to get into the logic and enable something, but is this switch really all the hardware I need to buy? Anyone done this?
Old Jan 24, 2017 | 11:15 PM
Kdr358's Avatar
Kdr358
I just added cruise to my 14 XL. It snapped right in! However you need to have the dealer activate it.
Old Jan 25, 2017 | 04:42 AM
Just Strokin's Avatar
Just Strokin
You should bee able to use FORScan to activate it. Check the 6.7 board for the FORScan thread. his would save a few bucks and a trip to sealer.
https://www.ford-trucks.com/forums/1...uilt-data.html
Old Jan 25, 2017 | 05:05 AM
Chuck's First Ford's Avatar
Chuck's First Ford
enjoy your "New to You" XL.
no details... 4x4 or not, long or short bed?
Old Jan 25, 2017 | 07:21 AM
thomabb's Avatar
thomabb
4X4 long bed, tuxedo black, manual everything, snow plow prep pack + 10k GVWR package = I am shopping for rear air bags.
Old Mar 16, 2021 | 06:29 AM
Andrew Cortese's Avatar
Andrew Cortese
I know this is an old thread but I’m trying to get cruises added to my 2016 f250 (6.7, 4x4, crew cab, short bed) I put the switch in and went into forscan and changed the setting in sccm and it says cruise control is enabled but it’s not. Is there other settings I need to change?
Old Mar 16, 2021 | 11:16 AM
Just Strokin
Here is the Ford instructions on installing the the switch and the programming needed. I believe you should be able to use FORSan to program it
https://www.fordservicecontent.com/F...18-aa--all.pdf
Use this spreadsheet to find the parameters you need to reset.
FORScan 2016 Super Duty - Google Sheets
CMB1998
Aug 28, 2024 01:26 PM
jeff69z28
May 7, 2019 11:52 AM
Fleetsuper
May 4, 2015 02:12 PM
mrwrench
Aug 5, 2011 11:33 PM
