Okay im just gonna go over the all the lighting issues i have and see if yall can point me in the right direction.
I have a 81 f250 4wd 4 speed. First off i bought it with no bed so it has aftermarket taillights on it.
it has one bulb on each side for brakes and turn signals. When i get a bed for how is the oem setup?
where is the reverse light at ? Ill have pictures later that ill post. And also the hazards arent working . And last the thing is my turn signals work but its super loose . So please any info on any of these
I am almost 100% sure both style side & flare side lights use the 1 bulb on each side like the lights you have now with the after market lights.
IIRC the style side is at the top of the light assy. but not 100% on that one.
Flare side light I also think it is in the housing at the top. Best would be to Google the 2 beds to look at the lights.
I am wrong the B/U light is down low
There is a 2nd flasher for 4 ways. One is on the back side of the fuse box.
Turn signal switch screws could be loose. Only way to know is pull the wheeland give a look see.
Dave ----
