cab and bed misaligned
Old Jan 23, 2017 | 05:54 PM
therigwelder's Avatar
therigwelder
my cab on my 96 f250 4 door truck is 2 inches lower on the body lines than the bed.it makes my truck look like its bowed in the middle.the frame is straight,i have found no body mounts on the back of the cab it appears to be bolted directly to the frame?whats up and how do i fix it?
Old Jan 23, 2017 | 07:26 PM
f1504x4driver's Avatar
f1504x4driver
Proud Pirate
Sounds like you have found the problem. Replace all the body bushings with new ones. Will look and sound better with everything aligned properly.
Old Jan 24, 2017 | 08:57 AM
joegeds's Avatar
joegeds
These might help - from the '96 service manual:
File Type: pdf
File Type: pdf
Old Jan 24, 2017 | 11:12 AM
therigwelder
I still don't see on the PDF where there are rear cab mounts.My truck is a 4x4 long bed ,crew cab 4 door. I am sure there should be bushings under the rear of the cab. My truck looks like it was bolted straight to the frame on the rear of the cab.when I got the truck the cab was sagging .I wonder if they wore out and a previous owner removed them ? Can anyone tell me if bushings go there and where I can get just those
Old Jan 29, 2017 | 11:04 AM
LeoJr's Avatar
LeoJr
Tilt the rear seat forward, remove trim necessary to lift the carpet, exposing the head of the bolt of the rear body bushing.
The middle bushing is just about right under your feet in the front seats. Gotta lift the carpet too.
The front can be seen with the hood up and looking straight down just behind the headlight. It can be reached with a couple of long extensions.
Old Jan 29, 2017 | 11:22 AM
LeoJr's Avatar
LeoJr
The bushing set I bought did not have the bolts like this kit seems to.
The upper and lower parts of the bushings have metal sleeves that are pressed together and need to be pulled apart. I cut the flared part off when I reinstalled.
I cobbled a puller out of some pipe and found a piece of threaded rod the same threads as the bolt and wrenched them apart. You will have to jack the cab up a little. Make sure all 6 bolts are loose but not removed as the cab can slip off the frame if you are careless. Some people removed the bolt from the top, poked it through a chain and threaded the bolt into the 'nut' underneath. The other end of the chain is attached to the floor jack, and as the cab is lifted, the chain pulls the two pieces apart.
Some have claimed that they have pounded them apart by hitting the loosened bolt inside the cab. I tried a few swings but found this method impractical for me.
Body Mount Bushings Kit - Ford F350 - 4.4123
Old Jan 29, 2017 | 01:47 PM
82F100SWB's Avatar
82F100SWB
Took a while to dig up a picture where you can actually see them, but this one does.
I doubt yours are missing, they are probably squashed or punched through the crossmember.
80ford100
Aug 8, 2016 09:55 AM
Nevada Al
17
Dec 24, 2012 08:23 AM
redman84
18
Apr 6, 2011 11:57 PM
dale gribble
22
Oct 17, 2008 05:22 PM
Jag Red 54
May 28, 2003 09:48 AM
