Fuel issues
Old Jan 23, 2017 | 12:19 PM
Jrecjr73's Avatar
Jrecjr73
Fuel issues
Does anybody know where i should start? My 7.3 is running but losing all power. Pumping the fuel pedle will get it started and it will run for a few then lose everything again. Should i just drop the tank and check the sending unit and intake and filters first then work my way up? Thanks for any info?
Old Jan 23, 2017 | 12:35 PM
F250_'s Avatar
F250_
WELCOME TO FTE!!
We need a little more to go on before pointing you in any specific direction.
1) Year and mileage, please.
2) Any recent repairs or modifications?
3) Any other symptoms showing up (i.e scanned for codes, rough running, smooth at startup but getting rough as it loses power, etc.)?
4) Ambient temperatures for your startup condition?
5) Have you verified that your oil level is full?
Without having answers to any of the above, I first think along the lines of fuel flow/pressure issues. When our fuel pumps get tired, or just cannot pump the fuel (cold weather gelling, plugged suction line, broken/cracked pickup tube in the tank), it can provide what you've described. Then again, so can low oil level and several other conditions.
Old Jan 30, 2017 | 08:22 PM
Jrecjr73's Avatar
Jrecjr73
Originally Posted by F250_
WELCOME TO FTE!!
I just want to thank you. I changes the oil a month ago.
all my dash guages showed everything was good. Well i checked my oil and it was dry. So i wasnt getting fuel. Bad o ring in the high pressure oul line. Not so bad i thought it might be a rear main. Whooo.
Old Jan 31, 2017 | 10:28 AM
F250_'s Avatar
F250_
Great. Thanks for the follow-up information, and I'm glad you resolved the problem easily enough.
One of my local diesel shops tells me that the single most common problem they find for when a Ford diesel runs rough and shuts down is "low oil level".
Old Feb 4, 2017 | 02:08 PM
crop harvester's Avatar
crop harvester
Rear main seal leaking is less likely the source of Your leak,It's more likely coming from a leak in the valley on top.
Old Feb 4, 2017 | 03:31 PM
coax9952's Avatar
coax9952
I'd be more worried how I lost 15 Qts of oil in less than a month......Are you bleeding oil somewhere?
jeremey1000
Aug 13, 2016 07:57 AM
lukasboy
May 20, 2015 03:24 PM
84-250
Jun 12, 2012 09:05 AM
mark460
Nov 10, 2011 03:19 PM
soyousee
29
Oct 1, 2008 06:04 PM
