Fuel Problem {I Think}
Old Sep 29, 2008 | 03:03 PM
soyousee's Avatar
soyousee
OK I have a 2002 F350 Diesel 7.3, starts and runs fore a little bit then dies, turned on ignition and hear pump running for 20 seconds or more before pressure shut down, Thought that was to long, so put on new pump, same thing. Opened fuel-water drain and turned on ignition and plenty of fuel shoots out. Help I'm 30 miles to the nearest dealer for mechanical help and no way to get it there. Last two times I tried it doesn't start at all, Is there a relay somewhere besides on the dash, Oh yes I checked the wreck shut-off switch and it's pushed in. Help
Old Sep 29, 2008 | 03:07 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Check:
1. Oil level - seriously, do it.*
2. How clean is your fuel filter?
*If you have an allen wrench (not sure of the size) then you'll want to check the oil level in your HPOP. If it's too low, their won't be sufficient oil to build the pressure needed to fire the injectors.
Others will chime in, but you'll need a 13mm socket to get the "PowerStroke" embossed plastic engine cover off to get to the HPOP & fuel filter.
Old Sep 29, 2008 | 03:10 PM
STROKIN'IT7.3's Avatar
STROKIN'IT7.3
The 20 seconds is normal... may have a blockage in the fuel pick up lines themself. Maybe take the fuel line off and take compressed air (with the fuel fill cap OFF!!!) and blow back threw the lines into the tank. More will chime in. Fuel filter too. Probably wouldnt be oil related if it runs for 5 mins.
Old Sep 29, 2008 | 03:23 PM
soyousee's Avatar
soyousee
Blew back into tank when changing pump as a precaution ,new filter installed first thing. Will check oil level in pump now.
Old Sep 29, 2008 | 03:34 PM
soyousee's Avatar
soyousee
OK checked the oil and it's full, dirty but full.
Old Sep 29, 2008 | 04:41 PM
megawatt00's Avatar
megawatt00
Clean oil will be of help also. When was the last time it was changed?
Old Sep 29, 2008 | 11:22 PM
DND58's Avatar
DND58
CPS's are pretty cheap these days. Unplugging the ICP is also pretty quick try. Just a thought.
DND58
Old Sep 29, 2008 | 11:30 PM
my79f's Avatar
my79f
i was just bout to say could this be a cps issue?
Old Sep 29, 2008 | 11:35 PM
AustinS's Avatar
AustinS
That does sound like it could be a cam position sensor. I would remove it, clean it up a bit if you don't have a replacement, check the wires on the connector and the pins on the sensor. Put it back in and see what happens.
Without codes it's tough to say.
Austin
Old Sep 30, 2008 | 12:15 PM
soyousee's Avatar
soyousee
Unpluged the ICP and tried to start, No dice. Going to get a CPS now.
Old Sep 30, 2008 | 01:52 PM
soyousee's Avatar
soyousee
EUREKA, got a CPS at Autozone for 30.00 and problem "almost" solved. Truck runs and I know that was the problem, only thing is I couldn't get the sensor in the hole with the O-ring on it so pluged it in to see and yes it was the problem. Called oldest son at the lease "Bowhunter" wants to top Dad's 8 point with bow and he's coming here to help me later today.
Thanks to everyone for their help, sept the guy that wanted me to change oil in the pump (lol) started to wash the windshield also but thought that wouldn't help eather.
Happy North Texas Rancher
Old Sep 30, 2008 | 01:57 PM
Smokin''s Avatar
Smokin'
Smokin
Glad you got it figured out.
I believe what Jim was saying is that clean oil may help, and to change all of the oil in the truck, not just the oil in the HPOP.
These trucks are oil pressure sensitive and will shut down when there is a loss of oil, or a fluid quality issue.
Old Sep 30, 2008 | 02:41 PM
STROKIN'IT7.3
Lisa is correct... these trucks will do funny things with bad oil.
Like the signature lisa
Old Sep 30, 2008 | 02:42 PM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
Fail to see any humor in these remarks. Low and or real dirty oil is often a problem with keeping these trucks running. You come on here looking for help we're going to point you in every possible direction.
Old Sep 30, 2008 | 03:05 PM
Smokin''s Avatar
Smokin'
Smokin
Glad you like it. It'll stay there unless someone else says something funny or witty.
