'98 Ford Ranger intake noise
Old Aug 27, 2003 | 09:38 PM
ahkmn's Avatar
ahkmn
Question '98 Ford Ranger intake noise
A friend of mine has a '98 Ford Ranger 4.0 liter that has a weird intake noise. The noise doesn't occur all the time, just tempermental. It sounds kinda like a shop vac. We took the lid off the filter box and let it run and the noise sounded like it was coming from around the MAF sensor. The truck runs like a top without missing a beat, and has around 70,000 miles on it. Could the MAF sensor be going bad???
Old Aug 27, 2003 | 10:39 PM
cow_boy104's Avatar
cow_boy104
Does it happen write when you start it up, and then stop a mintute or so later?
Old Aug 28, 2003 | 10:39 AM
Ken00's Avatar
Ken00
Sounds like the IAC, seems to be common on the 4.0.
Old Aug 28, 2003 | 11:09 AM
WXboy's Avatar
WXboy
Yup, that's what it is. Good ol' IAC valves...
Old Aug 28, 2003 | 01:08 PM
MSRanger's Avatar
MSRanger
Yep, if it sounds like a honking sound, that's it.
Mine would do it when I dropped to an idle, after driving about 1.5 to 2 miles from cold start. If you tap the throttle, it'll usually kill the noise.
Clean the IAC valve, per the posts here. Be sure to use Throttle Body cleaner, not carb cleaner.
Old Aug 28, 2003 | 08:56 PM
ahkmn's Avatar
ahkmn
ok, I will try that. Thank you for the quick replies!!!
Old Aug 28, 2003 | 09:45 PM
Rockledge's Avatar
Rockledge
This is a thread you should read through: IAC Valve Noise
nebechanezer
Feb 12, 2013 07:37 PM
dlmoye
Jun 9, 2012 04:36 PM
6LPSD
Jul 14, 2008 12:29 PM
carsrus
Feb 4, 2008 07:02 PM
firefighter525
Mar 13, 2003 06:12 AM
