Sponsored by: Real Truck
17,700 miles check engine light
Old Jan 22, 2017 | 07:10 PM
webmeister's Avatar
webmeister
My first check engine light...how exciting The fuel cap is tight so not that. Have an appointment with dealer, anything I should be aware of. Does this light come on for no reason? Wasn't expecting a light so soon in mileage...
Old Jan 22, 2017 | 07:42 PM
Chuck's First Ford's Avatar
Chuck's First Ford
100 things could cause a light.. maybe 200...
super simple to the moon.
poor fuel, water, bad connector...
Old Jan 22, 2017 | 10:53 PM
Tom's Avatar
Tom
Your sig shows a '17 Super Duty. Moving to that forum.
Old Jan 23, 2017 | 05:46 AM
DJ Cobb's Avatar
DJ Cobb
I would recommend getting an OBDII scanner in order to tell you why your check engine light is on, especially if there are no obvious indications why it came on....as mentioned above, there are hundreds of reasons and the scanner could let you know what it could possibly be. Ford however, will not care what your OBDII scanner says, they will diagnose it with their software (which will dig into your truck significantly deeper). While your truck is still under warranty now, you seem to be about half way to your 36k bumper to bumper warranty, it won't be in the future. Having the scanner will let you know what is up before you take it to the dealer to pay out of pocket later down the road.
Some of the more serious check engine light codes usually equate to noticable poor engine performance like bad injectors and faulty fuel injection control models or bad exhaust gas flow problems. The minor check engine codes can be self diagnostic sensor reading problems where the self test readings are out of tolerance. Anyway, let us know what code you got from the dealer (if they even tell you) and what the fix was! hope you get your truck back soon. Also, hope you get a loaner car too!
Old Jan 23, 2017 | 06:17 AM
Rooftop's Avatar
Rooftop
It's A diesel thing you will get used to it. My current 2012 6.7 had it on almost always because of emissions stuff. This may not be the case for everyone but if you do a quick search it's not hard to figure out these engines are complicated and are overly sensitive. Usually it's something very minor and will not affect performance. Like was already said getting a scanner tool is nice for peace of mind.
Old Jan 23, 2017 | 09:15 AM
Kenv's Avatar
Kenv
You have 17,700 miles on your '17????? LOL...what does your seat look like?
Old Jan 23, 2017 | 09:32 AM
webmeister's Avatar
webmeister
LOL now I see why all the reference to "2017". I have no idea how that happened...I have a "2016" ya'll. Now I just need to find out how to change it...where is the signature area
Old Jan 23, 2017 | 09:34 AM
webmeister's Avatar
webmeister
Found it! Thank you all for your assistance, I will let you know what the code is...hopefully.
Old Jan 23, 2017 | 10:04 AM
troverman's Avatar
troverman
Yes, it comes on for no reason at all.
Lol, sorry, I had to. Good luck getting it fixed.
Old Jan 23, 2017 | 10:10 AM
Tom's Avatar
Tom
Ha ha...moved back to the '99-'16 forum.
Old Jan 23, 2017 | 11:04 PM
TGD-IA's Avatar
TGD-IA
Ha, mine came on at 200 miles. Brake light wiring relay went bad. Welcome to Super Duty ownership.
Old Jan 24, 2017 | 09:06 AM
webmeister's Avatar
webmeister
NP Guess what I was getting at is that I am suspicious...light comes on just to get you in the door then sock it to you. Guess I need to learn more trust
Old Jan 27, 2017 | 05:35 PM
webmeister's Avatar
webmeister
HA! The light went off. They said that it did not have any memory to tell what the problem was so I cancelled the appointment. Self correcting, I love it...
alopez2
Nov 29, 2004 06:54 PM
ifosso
Escape & Escape Hybrid
Nov 17, 2004 02:20 PM
lowjo
Sep 6, 2003 08:55 AM
kramska
1983 - 2012 Ranger & B-Series
Sep 1, 2003 05:50 PM
gary.collins
Feb 4, 2003 11:23 PM
