little help on engine ID
Old Jan 21, 2017 | 05:45 PM
stuart olson's Avatar
stuart olson
see video.
https://www.youtube.com/watch?v=DavSCTS4OQk
Old Jan 21, 2017 | 07:32 PM
85e150's Avatar
85e150
It is a 2bbl FE with a horizontal oil filter (standard for pickups of that era) and a front sump pan with the "rust preventive" oil splash design, again, standard for the era.
It has pickup truck exhaust manifolds.
It is painted blue and it appears to original paint, which pegs it a '66 or later. It has "C8.." heads, which peg the heads at '68 or later, possibly as new as '71.
THAT, afaik, is all we can tell by looking at the outside.
Stick a wire down a plug hole. (see the FAQ at the top of the forum)
3.5 = 352/360, 3.75 (approx.) = 390.
All FE blocks up to a certain time in the '70s have "352" cast into the front as you show.
Old Jan 22, 2017 | 12:35 AM
stuart olson
Went and looked a little deeper at the block. The area that should have a block code is blank. does that mean anything? And yes I will check the stroke at some point here. Just making eventual rebuild plans and want to figure out if I have good cores for a mild 410 build.
Old Jan 22, 2017 | 05:05 AM
jowilker's Avatar
jowilker
X 2 on later 360 truck engine.
John
Old Feb 1, 2017 | 03:08 PM
wsu0702's Avatar
wsu0702
If the heads are original I would say it's a '68-'72 FE and not a later one. Starting sometime in ~'72 the truck blocks were cast with a mirror 105 instead of the 352 on the front of the block. Also around the same time the heads switched from C8AE-H to D2TE-AA parts. '68 was about the time that Ford quit casting the partial engineering numbers into the drivers side of blocks the DIF ("352") blocks. Check the casting date on the block it's located just below the oil filter adapter pad. Also the casting number/date on the intake will help narrow it down as well (assuming it's all original).
Old Feb 1, 2017 | 04:21 PM
jowilker's Avatar
jowilker
Was that when the 360 was introduced?
John
Old Feb 1, 2017 | 04:35 PM
wsu0702's Avatar
wsu0702
John
1968 was the first year for the 360.
Old Feb 2, 2017 | 01:46 PM
hotrodfeguy's Avatar
hotrodfeguy
68- about 71 casting codes were not really on most blocks in trucks. I would guess a 360/390. Only way to tell is pull a plug and measure the travel of the piston. 3.5 = 360 3.73/3.75 is a 390.
beaur
18
Aug 12, 2012 10:53 AM
flyinbrian04
Jan 20, 2008 08:45 AM
Argintessa
401, 477, & 534 SD Engines
Nov 16, 2006 10:25 AM
Annihilator
Mar 2, 2005 04:43 AM
JLinder2
Oct 31, 2004 11:16 AM
