Bottom end bearings
Old Jan 22, 2017 | 01:48 PM
Djstright's Avatar
Djstright
Bottom end bearings
so I've got my 360 tore down and it's clearly been rebuilt before and I'm wondering how can I tell if the bearings are done? They don't have any bad groves and the oil pressure was always fine but the copper colour is startig to show.
Old Jan 22, 2017 | 02:01 PM
69cj's Avatar
69cj
Once I had it torn down like that, it'd be getting new bearings no matter how they looked and the crank would also be checked.
Old Jan 22, 2017 | 03:02 PM
Destroked 450's Avatar
Destroked 450
Old rule of thumb was if the coppers showing they need replacing. Lot of copper showing on the rod side and that is where most rod bearing wear occurs, main bearings wear more on the cap side.
With the bearing wear I see I'd have the block and crank both checked.
Old Jan 23, 2017 | 07:28 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
With the wear off to one side like that, the block might be due for a line-hone.
Old Jan 24, 2017 | 08:58 PM
Nick-1973-ford's Avatar
Nick-1973-ford
Rebuilding an engine is not just replacing the bearings. Depending on the extent of the rebuilt you are doing I would: get all the new bearings for the bottom end - including camshaft. I would turn and polish the crank (balance it also). Get all new piston rings.
Again, depends on what you are doing and how much you want to spend. If your motor is apart do as much as possible.
Nick
Old Feb 2, 2017 | 01:57 PM
hotrodfeguy's Avatar
hotrodfeguy
Depending on your performance level dictates what you need. If just a truck that hauls stuff a normal rering and bearings are fine. But as you up the power things need closer attention.
tfurman6
Aug 22, 2013 08:26 PM
maribou912
23
Jul 9, 2012 11:37 PM
mabigredtruck
21
Nov 21, 2010 12:57 AM
Argess
13
Oct 16, 2010 12:03 PM
ted368
May 9, 2005 12:58 PM
