Need Ideas : Grill Reinstall
Old Jan 21, 2017 | 12:45 PM
kdmercer311's Avatar
kdmercer311
Lightbulb Need Ideas : Grill Reinstall
Hell Again!
Here's where we are.... After combing through posts I realized that the removal of the '66 grill off of my '65 Slick was not going to be an easy thing to do. Through sheer determination, a cutting wheel, and a good set of drill bits I finally got the darn thing off!!!
Now comes the problem, after I'm done sanding and painting I'll eventually want to put it back on. As you probably know there was a lot of spinning nuts that I assume had been welded on 52 years ago.
Is there a solution to this that will not require more welding? The main two that concern me are the two at bottom center that also connected the two arms that run from the hood mechanism down to the radiator support.
Please forgive any errors in my description, I've been learning as I go since October when I got the truck.
Old Jan 21, 2017 | 02:07 PM
SuperSabre's Avatar
SuperSabre
It's been several years since I did it, but I seem to remember that I did the grille and gravel pan together as an assembly, off the truck, and probably the two bolts of the hood latch assembly at the bottom as well, and then mounted the whole assembly into the grille opening. So to do it the way I'm describing, you'll have to remove the gravel pan from your truck and then attach the grille bottom to it. Does that make any sense? Good luck!
Old Jan 21, 2017 | 02:16 PM
dank4120's Avatar
dank4120
When we reinstalled the grille, most of the welded on nuts were still intact, and any that were not, we just used a regular bolt/nut.
However, it's still a real pain to get your wrench in to tighten the bottom of the grille to the rock guard/stone deflector, as you already know.
We already had the stone deflector off, so we bolted it onto the grille first, then installed the new combo-piece, see pg. 17, about 1/2 ways down.
https://www.ford-trucks.com/forums/1...-build-17.html
Old Jan 21, 2017 | 02:33 PM
daveengelson's Avatar
daveengelson
My attempt to explain is probly worse than U's description?
With the bumper removed, I found the major pain in the backside was securing the bottom of the grille to the splash pan, so I attached to the splash pan to the grille then installing both as a unit. Installed the 'J' and/or 'U' nuts to the pan, the bolts/screws securing the grille to the splash pan are accessible. Once the grille is secured, not too tight for minor adjustment, I then installed the grille support bracket, should be an opening on the back of the radiator support where I used a 1/4" socket to attach the bracket at the top, seem to recall attaching the bottom of the bracket at the base was relatively easier, suggest replace the castle nuts, or clean and tap beforehand.
Looking forward to other member's input as to how they went about it?
Old Jan 21, 2017 | 02:48 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
When I removed the grille in my '65, I also removed the upper and lower panels separately. Doing it this way was a study in futility!
So when I replaced the old grille with a new grille, I bolted it to the upper grille panel (8190) and lower valance panel (17A862), then installed it as an assembly.
8188 lower deflector in pic: 1961/65 F100/250 4WD; 1961/66 F350/750; 1966 F250 4WD only.
Old Jan 21, 2017 | 03:36 PM
kdmercer311
Thanks for the replies. I fly home Thursday night and plan on spending all day Friday with the truck. I'll get some more pics too as I have a couple questions that are pointless to ask without a good example.
Here is what I've done with both bumpers ....
I plan on doing the same to my grill, although I don't think it'll be as easy to get it stripped down as far as I did the bumpers. I may have gotten carried away and not needed to go all the way to bare metal but it was my first big painting project and I was excited!! Any suggestions or techniques for sand and paint on the grill would be greatly appreciated. Those bumpers came out good I think but the journey there was a long one!!
Old Jan 25, 2017 | 07:03 PM
Fords & Whalers's Avatar
Fords & Whalers
I'm planning the same project in the not-so-distant future. Here's some advice I got from forum member TripleFrame:
Black trim paint was used on all standard '61-'66 F 100 pickups grills, as well as radiator supports. This allows the grill pattern to "float". Sales literature rarely show standard model pickups, so a medium duty ad will have to do. 1965 Ford Medium Duty Truck Brochure 16202-5AN2GV Note how the black trim paint continuously surrounds grill. Also area behind headlight buckets are black(not seen when buckets are installed). Whimbledon White was used on '64 -'66 F 100 pickups for standard grills, and bumpers, except if truck was painted a special order fleet color or pure white (bright white).
Old Feb 14, 2017 | 02:10 PM
kdmercer311
Sorry for the hiatus guys, I've been wrapped up tight. Here's where I'm at with the Grill Reinstall.
Here are the turn signal bezels and the bumper. Bezels are still wet, bumper is about to go on!!!
Tomorrow the grill and all four bezels should be ready to install. I'm pumped and will up date on whether it ends in success or another day needed..
Old Feb 14, 2017 | 09:11 PM
dank4120's Avatar
dank4120
Looks great. I haven't seen many paint the park/signal lamp bezels, but I think it'll look good, a nice custom touch!
Old Feb 15, 2017 | 08:20 AM
kdmercer311
Wouldn't you know it.. Got up this morning around 0645 all excited to get the boy on the bus headed for school and get started on the grill install. And it's raining like a horse pi$$ing on a flat rock outside!!
I'm going to rise above though just swept out the garage about to pull her in and get going. Will update soon.
Old Feb 15, 2017 | 10:22 AM
kdmercer311
Could not ask for more!! It went way smoother than I hoped it would at best
Replaced all the rusted out bolts with new ones from Home Depot.
This is how I avoided removing the stone shield. It would have taken way longer to fight more rusted bolts than it did to drill to 3/4 in holes.
Grill is on!!!
Moving on to headlight bezels then bumper... Stay Tuned
Old Feb 15, 2017 | 01:55 PM
yankbs 66f100's Avatar
yankbs 66f100
The grill looks great. Sometimes you have to think outside the box to get back together. Congrats kd.
Old Feb 15, 2017 | 02:52 PM
kdmercer311
Got it all back together. Today was a good day!!!
She may not be perfect but she mine all mine!!
Old Feb 15, 2017 | 03:13 PM
yankbs 66f100
Looks awesome. That's how I feel about mine, she may be a 10 to 20 foot paint job, but it gets the job done for me. Enjoy it, and don't be afraid to use it.
Old Feb 15, 2017 | 06:41 PM
dank4120's Avatar
dank4120
Yep, that does look good. I managed to scratch my bumper a month after I pulled it out the Paint Shop. I was mad, but no fun having a Slick if you don't drive it, just like Bob says!
