Please Need Help With Timing a 410 FE
Last summer I did a ton of work to the motor trying to get it up and running. I put a new Edelbrock intake, New Holley carb with 1" aluminum spacer, aluminum radiator, water pump, thermostat, 3G swap, Mark VIII electric fan, New flamethrower coil, plugs and 8mm wires, Sanderson headers and several other small things like vacuum and fuel hose.
When I pulled the distributor I made sure to mark it several ways so it would go back in correctly. I am sure I got it right for how the motor was set up before but after the modifications it isn't quite right. It ran great at idle and would shoot flames out of the headers after you got on it. But when you would put it in gear and the engine was under a load it would bog down and not really run right. Me and a buddy tried turning the dizzy and it started to idle better but we can't turn it any further because the vac advance hits the manifold. I know the timing is the issue and that I'll have to pull the dizzy. I have tried to do as much research on it as possible but still don't feel 100% confident in getting it right.
I know there are a ton of threads on this but I am hoping for a run down and step by step instructions specific to my application. I have to move the truck from my house because my lease is about to be up. Any and all help is greatly appreciated.
You're just "a tooth off" is all, when you stabbed the distributor into the engine. That's why you run out of room to set the base timing. The helical gear on the dizzy shaft means you have to lead it pretty good to get it to line up correctly when it's fully seated.
As a practical matter this is why you'll see "previous owner" rigs with the wiring at the distributor cap off from factory. The distributor doesn't care, so long as the firing order is correct it will run fine. You can move all the wires on the distributor cap over one iteration (probably CCW) to compensate for the error and get it to run right i.e. be able to set the timing, without having to remove the distributor, if you're in a pinch.
So the quick "fix" is then installing the spark plug wires at the distributor 180° out, then all is right in the world again.
Except, when somebody else ever tries to time the engine with a light, say. The #1 cylinder wire ain't the #1 cylinder no more. So... when he puts a timing light on the #1 spark plug wire... he gets confused. Ask me how I know.
I would take the time to get the distributor installed correctly, then the timing marks will be accurate. Line everything up at TDC compression stroke #1. Look at where the rotor points right now. Most likely it is pointing at whatever # is next in the firing order after #1. You prolly need to "back it up" 1. Pull the distributor out and finagle it and the rotor shaft with enough windage or lead so it finally ends up one click farther over than before, CCW most likely. Make sure distributor is seated all the way and not hung up on something and feels right. Don't force it, it will just drop right in at the magic moment.
If it's taking too long and starting to feel like a career sometimes you can roll the crankshaft clockwise just a smidge... and try again. When it's finally stabbed correctly can make a mark with a scribe or sharpie or just eyeball it for future reference. On my Y block the rotor point ends up exactly parallel with one of the snap clips that holds the cap on. So long as #1 is at TDC compression, and the rotor is pointing there, it will fire right up and idle nice. It helps to have an assistant who might need to advance or retard the distributor during that first crank to start, an engine won't idle well till the timing is in the ballpark. Be careful of backfire, don't flood it out or roast your starter.
Another scribe line is useful so you can set the distributor itself where it needs to be timing wise once that's sorted out. Ignition Timing itself is a whole nother subject, for now get distributor squared away and set it at 12° BTDC w/ vac disconnected and plugged and see how it runs. You'll want a tach, and a mechanics vacuum gauge to tune and diagnose how things are running. Always disconnect and plug the vacuum advance port when setting timing and setting up distributor advance up to around 3000 RPM.
Agree it is a good idea to check TDC timing marks first. The basic process is to install a positive stop in #1 spark plug hole which blocks the piston. Roll the engine by hand until it hits the stop and mark the damper. Roll the other way and mark again. Halfway in between the two marks is "true" TDC.
If you need to move the distributor a tooth or index the sparkplug leads to get the right timing, then have at it!
One improvised trick I use to get them to drop that last step and engage the oil pump driveshaft is to put the car in maybe third or fourth gear, if it's a manual, and then if the dizzy doesn't drop that final step, I'll push the car with my knees on the bumper, and then maybe pull back on the radiator support if the push didn't get it. That often works. Trucks and old cars afford you the luxury of being able to grab and turn the crankshaft pulley.
Ive got a vacuum gauge and a timing light so when i mess with it in the next couple days ill let you know of my readings and where it was. Its gonna be raining for a couple days and i dont have a garage so i have to find a good time to do it
Thanks again for the advice guys its been a huge help
So I when I tried to reinstall the dizzy to the right tooth I pulled up the oil pump driveshaft with it. Now I'm not sure what to do since I don't want to drop it down into the pan. And I know I'm at TDC but not sure if it's on the exhaust or compression stroke. How can I tell the difference? Is it if it pushes air out of the spark plug hole?
The bad part of the update is I just found out instead of the ultra black gasket maker I somehow bought black adhesive sealant instead. And of course this past summer I did the whole manifold seal with it and the headers as well. So now I have to redo all that. I didn't really want to but I think I am going to pull the motor out. I want to reseal, flush freeze plugs in block, and paint the whole motor and I can put it on a stand in my buddy's garage to do it.
So the shift of my timing needs is to start over with timing and stabbing the distributor from scratch after I reinstall the intake. Do I follow the same procedures if I don't have any marks for the distributor? Just find TDC on number one cylinder and make sure the rotor is pointing to number one wire?
