DEF.....what are you using
Old Jan 17, 2017 | 04:50 PM
redz284u's Avatar
redz284u
so my first fill of DEF is coming up. Are you guys paying the 30$/2.5 gal motorcraft wants????
is all DEF created equal??? Walmart has def $8.99/2.5 gal. Peak blue def sells for $10/2.5 gal. Valvoline for 12$
They are all 32.5% Urea.....
Old Jan 17, 2017 | 04:58 PM
EpicCowlick's Avatar
EpicCowlick
DEF is DEF as long as it is major brand and relatively fresh. It does degrade over time. I've bought a lot of DEF at Wally World over the years.
Old Jan 17, 2017 | 05:05 PM
C.moore01's Avatar
C.moore01
Just topped mine off with super tech def .. its all the same stuff
Old Jan 17, 2017 | 05:14 PM
coolidge54's Avatar
coolidge54
Red how many miles do you have on your truck? I'm at 1,800 and my DEF still reads full.
Old Jan 17, 2017 | 05:16 PM
redz284u's Avatar
redz284u
im at 3200 and have 1/4 left......
Old Jan 17, 2017 | 05:33 PM
fidel.medrano's Avatar
fidel.medrano
I use the nozzles at my local gas station. 2.15ish a gallon? something like that.
Old Jan 17, 2017 | 05:36 PM
Oz97tj's Avatar
Oz97tj
Truck stop is usually a little over 2 bucks a gallon...
Old Jan 17, 2017 | 05:43 PM
C.moore01's Avatar
C.moore01
I used 3/4 of def over 8k miles
Old Jan 17, 2017 | 05:45 PM
redz284u's Avatar
redz284u
8k miles?????? Should I be concerned I'm only at 3200?
Old Jan 17, 2017 | 06:00 PM
Dylan01's Avatar
Dylan01
Towing heavy, I was due for DEF right before 5k miles. I am skeptical that my dealer did not fill it entirely.
Old Jan 17, 2017 | 07:11 PM
C.moore01's Avatar
C.moore01
They say def usage is dictated by fuel mileage, so the more you tow the more you'll use .. i haven't towed anything heavy yet
Old Jan 17, 2017 | 07:35 PM
Fmc4lfe's Avatar
Fmc4lfe
Use the high performance def I picked up like 15lb ft on it
Old Jan 17, 2017 | 08:00 PM
17_F350_KR's Avatar
17_F350_KR
I was expecting it would improve my audio quality
Old Jan 17, 2017 | 11:01 PM
EpicCowlick
DEF usage is dependent upon exhaust temps. Nitrous Oxide (?) is caustic and produced at high temps like when you're towing. The DEF woks as a catalyst to convert the NO into inert gasses. If you tow a lot, you use more DEF.
Old Jan 18, 2017 | 07:07 AM
troverman's Avatar
troverman
I typically have the dealer refill it at oil change time. In a few hundred more miles, I'll be at 5k and will have the oil changed. Right now, DEF is less than 1/4 and I'm expecting the warnings to start soon.
