Adding oil and coolant filtration, any recommendations?
I want to add a secondary oil filtration and also a coolant filter. Im looking at sinister diesel, and a setup on diesel site.
Id like to hear what you guys are running for filtration. Any pros cons of these two models, etc.
Also, do any of you have an external transmission filter installed? I have on on my 7.3, and so far so good.
Thank you.
Thank you.
When I bought my truck it had 85 k on it. Has a coolant leak at the pump. Drained the coolant and there was junk in it. Refilled and added a coolant filter and the leak stopped. I don't think pump seals work well with sand in it...reports from other members say that sand is the biggest find in the filter.
and sure, once your sure you have all the casting sand out you probably don't need the filter anymore.
jwhopson
15
12-28-2014 02:32 PM
