Exhaust manifold bolt
Old 01-15-2017, 09:34 PM
Jsek's Avatar
Jsek
Jsek is offline
I struggled with the manifold bolt closest to cylinder #4 (firewall side) with the manifold on... Even with fender and skirt off. What tricks do you all have?
Old 01-15-2017, 10:15 PM
thrifty's Avatar
thrifty
thrifty is offline
clean the oil off,Go to you tube and check out the videos about candle wax for broken bolts, and studs. Heat the bolt with propane torch touch the surface with the wax. It penetrates the threads.
Old 01-18-2017, 10:59 PM
Jsek's Avatar
Jsek
Jsek is offline
Thank you for the reply. For clarification, the bolt itself was not hard to get out. I'm hip on getting stuck bolts out at this point ��. This bolt was a very tight fit and getting access to the bolt with manifold on was my challenge.
Old 01-19-2017, 05:16 AM
Walston's Avatar
Walston
Walston is offline
You may be able to access it easier if you remove the transmission cover and reach it from inside the cab. I am not certain, but it may be worth considering.
totavikid
10-01-2023 12:28 PM
Restlesswildman
05-10-2016 09:56 PM
Fordzilla80
31
04-27-2009 09:43 PM
flipklos
01-02-2009 02:07 AM
the kid
11-22-2006 10:29 PM
Quick Reply: Exhaust manifold bolt
