questions on manifold replacement
Old Nov 22, 2006 | 05:24 PM
the kid's Avatar
the kid
hi i cracked the combo manifold on my truck so i need to replace it. is there any tricks to doing this. would spraying the blots with pb blaster do any good or not i dont want to brake a bolt off in the block. thaks
Old Nov 22, 2006 | 07:54 PM
385seriesHemi's Avatar
385seriesHemi
Well if you are worried about breakin the bolts off, soak them alot be you try to break them loose. If all else fails use heat like a small propane torch to heat the area around the bolt. Remember expand around the bolt and not the bolt itself, just take your time basically.
Old Nov 22, 2006 | 10:29 PM
Boss429F150's Avatar
Boss429F150
on my other tuck the bolts looked horrible and they came right out with little effort.
