I want to replace all my bushings for the springs on my 62 Uni. I bought polyurethane bushing for the rear, but I have been unable to find any for the front. I might be able to find replacement rubber bushings (I'd prefer poly), but I'm not really certain about that. Are these parts a one year only part or something? Are some other years interchangeable maybe? I did a search on the forum, but couldn't come up with an answer. I've also read some stuff on newer rubber parts being questionable, so that another reason I'd like to go with the poly.
Do you want the bushings for the front or rear springs, or both?
Front bushings is what I am looking for.
I have already purchased rear polyurethane bushing, but have not installed them yet. I was thinking of installing my front bumper, but decided that it may be easier to do the bushings before I install the bumper.
2) C1TZ-5304-G .. Front Spring FRONT Bushing Kit / Obsolete
See pic below: Kit consists of 1 upper (5348) and 1 lower (5781) bushing, 2 bars (5348) and hardware (bolts/nuts/washers).
Applications: 1961/64 F100/250 2WD & 4WD
NOS PARTS LTD in Waxahachie TX has 2 = 972-937-2201.
GREEN SALES CO. in Cincinnati OH has 5 = 800-543-4959.
MILLER OBSOLETE PARTS in Binghamton NY has 10 = 607-722-5371.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 10 = 800-476-9653.
Bushings only:
2) C1TT-5348-B .. Front Spring FRONT Upper Bushing / Obsolete
B. F. WHITE MOTOR CO. in Stanton TX has 2 = 432-756-3321.
OBSOLETE RELIABLE PARTS in Nashville GA has 2 = 229-686-5101.
NOS PARTS LTD has 3.
CARPENTER NOS OBSOLETE PARTS has 3.
2) C1TT-5781-D .. Front Spring FRONT Lower Bushing / Obsolete
B. F. WHITE MOTOR CO. has 2.
MCDONALD OBSOLETE PARTS in Rockport IN has 3 = 812-359-4965.
MILLER OBSOLETE PARTS has 5.
AL WHITE MOTORS in Manchester TN has 6 = 931-728-9700.
I have spoken to the techs at Energy Suspension and been told that, although they may not make a kit for your application, if you can give them the size spec's of the bushings you need, they probably have something in their catalog that would fit your need.
So according to this info, the same bushing should fit all 61-64 F100's. I wonder why they don't list them as such?
Thanks for the information, that's good to know. I wouldn't know where to get the specs, unless I try to mic them in place. I would prefer to have new ones on hand when I get into the disassembly. According to Bill, I might be able to search for other years (61-64), and just go with them.
C1TT-5348-B .. Front Spring FRONT Upper Bushing: 1961/64 F100/250 2WD/4WD
C1TZ-5348-A .. Front Spring FRONT Rear Bushing: 1961/64 F100/250 2WD
Lower pic: 5781
C1TT-5781-D .. Front Spring FRONT Lower Bushing: 1961/64 F100/250 2WD/4WD
Lower pic: 5781
Wow, you are the man Bill. Didn't really expect you to have that info. 🙏
