Your Ford ones are still going well at 136K, seems like they've worked fine for you. While I read about a failure here and there, it isn't something frequent suggesting the Ford parts are sub-par. I'd just go back with Ford ones personally...
Sorry, I haven't heard of upgraded units so can't help you there...
Nice post - I had to rep ya' for that one -- how many miles were on those when you re-packed and did you re-use the seals or get new ones?
Just reuse the seals, just be careful when removing them!!! You don't have to pack um full ether, I use mystic hi-temp multi-purpose grease, it's the bomb! Lol! That's funny right there, I'm almost 60!!!!!! Omg!
I did them all last week, did a transmission fluid change on the 02 today!
275'xxx on the 2000
117'xxx on the 2002
128'xxx on the 2005
275'xxx on the 2000
117'xxx on the 2002
128'xxx on the 2005
Thank you! I'm soooo doing this when the belt comes off this weekend for the water pump install!!
I'll hit seals with a heat gun to warm it up and hopefully prevent it from cracking.
I paid about $7 each for the bearings from my local Trans-Bearing store, so any specialty shop that sells bearing and seals. And they were a very good quality.
