PowerMax 2 or the KC 1.5?
Everything installed to support increased power and the stock turbo is showing signs of wear... it's time to upgrade. I've heard the PM1 is an EGT maker, not looking for that, anything on the PM2 or KC 1.5?
I plan to revise the tune, want to tow so won't go higher than this and most likely will stay stock injectors for now. This should put me into the 500hp range as the next is a transmission upgrade. Reality, I'm probably close to this already.
Thanks for the inputs.
I had the intake off the other day, radial play is starting to develop. I'm not sure if the 360° bearing will fix that or if I need a turbo. I'm thinking this is a good excuse to upgrade and take advantage of the mods I've installed and have a little more fun while at it.
white Buffalo
130
07-19-2014 08:26 AM
montanasteve
48
06-04-2014 08:06 PM
spdmpo
91
02-23-2011 03:22 PM
