1978 - 1996 Big Bronco
Bronco obd1 code "8 cyl"
Old Jan 11, 2017 | 12:02 PM
Cummins7mm's Avatar
Cummins7mm
My check engine light is on in my 92' bronco 5.0 5 speed manual it usually comes on when I get up to 30 MPH. I have a OBD1 code reader for the connectors under the hood. According to the instruction manual for the code reader " cyl" means cylinder, and the code is "8." So if I understand correctly there is a problem with the 8th cylinder. Any idea what I should check/change.
Old Jan 11, 2017 | 01:20 PM
jimbo285's Avatar
jimbo285
It's been a while since I performed a KOER test but during the idle check my reader has me verify it is an 8 cyl before the test will run. Then, the codes will display, if any.
Old Jan 11, 2017 | 04:30 PM
rla2005's Avatar
rla2005
Start with the Key On Engine Off (KOEO) tests and stored (Continuous Memory) code display. Fix any issues flagged there before running the KOER tests. The Check Engine Light is triggered from a stored code.
The answer to "So if I understand correctly there is a problem with the 8th cylinder." is no, you do not understand that correctly. Cyl 8 simply means the computer thinks it is attached to an 8 cylinder engine.
Dozeman
Apr 21, 2013 06:29 AM
skipperbry
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jan 17, 2012 08:03 PM
dkrobson
Jul 29, 2008 04:41 PM
malveaux0089
May 26, 2007 09:50 PM
neoflee
Aug 27, 2005 11:01 AM
