connector pin cleaning
Old Jan 11, 2017 | 09:57 AM
IDIoit's Avatar
IDIoit
the main connector to the engine has pins with a bit of corrosion on them.
the truck has been torn apart and sitting for a few months.
and I don't want to put it together without seeing the pins shine.
whats the best way to go about cleaning them?
ive tried spray electrical contact cleaner, but it wont get rid of the ruff stuff.
I see the common green corrosion on them.
Old Jan 11, 2017 | 12:32 PM
F250_'s Avatar
F250_
Never dealt with this myself.
Perhaps this link will give you some good ideas.
Best way to remove corrosion from electrical pin connectors | Adventure Rider
Here is another one which may just be the ticket for you. http://www.instructables.com/id/How-...es-in-minutes/
Old Jan 11, 2017 | 01:26 PM
IDIoit's Avatar
IDIoit
sweet! I appreciate it, vinegar, salt and baking soda it is!
Old Jan 11, 2017 | 02:18 PM
brian42's Avatar
brian42
Veteran: Navy
I've also used a toothbrush to help scrub some of the more stubborn corrosion off. Soft bristles and a gentle touch won't bend any pins.
Old Jan 11, 2017 | 02:23 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Electrical contact cleaner at any parts store is good to have on hand as well. It will serve as a good rinse for anything you have done to the pins.
Usmc6.0
May 31, 2017 01:22 PM
windsor8689
Feb 15, 2011 09:26 PM
pappy19
Appearance & Dress-Up
May 18, 2010 10:27 PM
Hiflyer746
Nov 20, 2009 06:15 PM
01PS
May 22, 2008 09:30 AM
